Shop Compressor
Shop Compressor
Shop Compressor
Howard
>I will be piping a new compressor when my shop is finished. How often do you drain the air?
Re: Shop Compressor
Depends...
>on how much you use the compressor and ambient conditions. I have had an IR two stage unit installed in my air conditioned shop for about five years, probably used for a total of fifty hours, and there's never been any accumulation of water. I only power it when in use and leave it pressurized otherwise.
Clint
Re: Shop Compressor
Continuously *LINK*
>And automatically.
I have installed a pressure-activated condensate drain valve that cycles with a drop of 10psi which at least once every fill. It attaches to the tank drain which will need a street elbow and nipple to bring the unit clear of the tank. Price is $50.00 at McMaster-Carr whose part No. is 4919K13. Goto the link and input the number in the search box
McMaster-Carr
Re: Shop Compressor
Re: Continuously
Kneale Brownson Dreaming of the Snow in N. MI
>Description says it's activated by compressed air supplied by an 1/8" line. Is that something you have to plumb in separately? If so, can you use the same tap as the drain with a tee and reducer to provide the air?
Re: Shop Compressor
Re: Continuously
>Remove the existing petcock drain (it will fail if used on a regular basis), and put in a 90� brass el, then a brass nipple of enough length to get the valve free of the tank. My tank took 3/8" piping that I then reduced to a 1/4" ball valve as a cut-off, then into the 1/4" auto drain. That's all it takes, although I did put on a bit of flex tube to direct the squirt. The ball valve acts as a cut off to hold tank air if I ever have to take the auto drain off the service it. 5 years without a hitch.
mm
Re: Shop Compressor
Re: Shop Compressor
Howard
>Thanks for the comments, I will take the petcock off and replace with a ball valve. Thanks again
