>I have about 50-60 images of various structures for which I would like to determine the approximate heights and widths. Is there some sort of utility I can download that will overlay a configurable measuring tool on the computer screen such that if I tell it what size represents a foot or a meter, I could then drag a cursor across an area of the picture and it would display the dimensions?
I did many of these for my work before I retired. There may well be some software, but I didn't use anything special. I found it quick enough to load the image into Photoshop, figure a conversion factor between the known measurement and image scale, and enter that factor into a calculator. I'd measure, either with the measuring tool or by dragging a rectangular selection area and watching the Info box, then type the number into the calculator to convert. If working from a paper image or drawing, I'd write down all the numbers on the drawing then convert them all at once, perhaps with Excel.
If I had a lot of measurement to do on one image, I sometimes used a different method: first figure the scaling factor, then scale the entire image so I could read the on-screen measurement without converting. For example, I might scale the image such that 10 pixels = 1.0 inch, then 382 pixels would be 38.2 inches.
Occasionally I would load an image into one of my other packages, such as Autocad or 3D Studio Max and set the scaling to read inches and feet (or meters) directly, but that was usually more trouble that it was worth.
The biggest problem is usually determining the image scale! I often figured the scale by measuring a few features on the building while I was taking the photographs, or scaling from standard door heights. If the building photo is in mild perspective, sometimes the perspective warping feature of Photoshop can straighten it. Sometimes guessing was close enough. Other times, especially where perspective was extreme and the measurements needed to be closer, I would use a 3D program like 3DStudio Max or Sketchup to build "ghost" or wireframe models on top the picture and measure these models. The hardest thing about that is getting the 3D camera perspective correct, but there are ways.
If measurements were critical, I would use tapes, measuring wheels, and whatever to measure the buildings. This took a long time but gave the best results. Of course this is not useful unless you have access to the building!
BTW, I did this type of work to create 3D models for site planning and to visualize building modifications and additions.
>That's more or less the way I've been doing it but I was hoping to find an easier way than stopping to calculate a conversion factor for each picture (the scales are not consistent from one picture to another so each one has to be calculated separately).
Use Adobe Photoshop Elements (old versions are free downloads) and turn the grid on. Then set the grid to an appropriate interval and I've got a reference.
Or, I use this free program that allows you to set a scale (eg 217 pixels = 3') and measure distances.
Note: free registration may be required to download.
>Thanks. That is one of the ones I found while googling but wasn't sure from the description of features if I could configure it with a custom scale. However, I discovered there is a more up-to-date version (3.5) and that definitely will do what I want.
>Thanks. I spotted that one and it looks pretty cool. However, unlike the situation in the physical world with a woodworking tool, I don't know if I can bring myself to pay for a tool that I would need for only one small project.
