THE WOODRAT IS BACK!
So my friend asks me to help repair a dresser
Lee Schierer - McKean, PA
>A friend has a dresser that his daughter has used for a number of years. This dressser had four drawers riding on a center metal drawer guide on the bottom of each drawer. These guides were worn out and two had come loose. He asked me if I could put in new drawer guides and get a few more years out of the dresser. I agreed to take a look at it. Well shall we say it is not heirloom quality construction. It was constructed of MDF and particle board. Nonetheless, I figured I could put on some side mounted drawer slides. I bought some 1 x 3 poplar to make runner supports spanning between the front frame and the rear. I decided to do the top drawer first. I installed the new rails, making sure they were perpendicular to the face frame and parallel to each other. I figured out where the new side mounted slide needed to be mounted on the side of the drawer so the drawer front would align properly to the opening. I put the parts together, slid the drawer in and the fit was perfect. So far so good.
Then I went into production mode, installing all the slides on the remaining 3 drawers, mounting the six remaining wood runner supports and drawer slide in position, again making sure they were perpendicular to the face frame and parallel. I got all the parts in place and tried the next drawer. It went in fine, but one side stuck out about 1/2" while the other side was flush. I check all my alignments, everything was perfect. I checked another drawer it fit better but not perfect.
At that point I started checking the drawers. The sides were parallel, but not perpendicular to the front and the back was bowed in about 1/2" in the center. The top drawer was nearly perfect. I had to adjust each set of runners so the drawer would slide in and set flush on both sides. All three of the larger drawers are out of square by differing amounts. If you put them in and adjust that set of runners to fit the drawer, the drawers are no longer interchangeable. I marked them for location and will get it back to him this weekend.
A pretty simple job got more complicated and took twice as long as it should.
Lee
Re: So my friend asks me to help repair a dresser
been there myself
Bill Tindall, E.TN
>but the work is appreciated, if not rewarding.
Re: been there myself
Chuck in ND
>Doesn't it allways go like that ?
For Me, It Does, Chuck!
>Good Afternoon Lee,
My present project, a master bedroom suite, is ape with drawers. Rather than squander the smnall amount of common sence I have remaining, I decided to make center mounted wooden slides and guides. They all work, and the fronts are `pretty much where they should be when closed. However, each of the drawers is slightly different from the others in each piece. All the tracking had to be done individually, and the drawers are all numbered. Even mass production output is essentially one unit at a time, so I don't feel too bad. Maybe Norm uses mirrors. His are always perfect. The difference can be measures by his skill and my beer. :<)
George
must have been pretty good friends
Tom Sontag - St. Louis
>It would take a pretty special relationship to suck me into that kind of duty. Might as well ask me to snake out a clogged drain. Good on you for enduring the ordeal.
(Lest I sound like a total curmudgeon, I actually DO perform favors like this at times. I never enjoy it.)
