Air Drying Lumber
Air Drying Lumber
Air Drying Lumber
Dan Collins
>Friends: I just used my chain saw mill to mill some cherry logs into nice one inch boards. I plan to sticker and air dry them for a year or so. I live in Wisconsin and have a small residential lot. I don't have a real good place to leave a stack of boards for a year. My garage has open air rafters that are level (the pitch of the roof is quite steep so there is a lot of open space in the rafters). The garage is unattached and not heated. I suspect the rafter area gets real warm in the summer. Does anyone have any positive or negative experience with drying wood up in the rafters of an unheated structure? Thanks. Dan
Re: Air Drying Lumber
Re: Air Drying Cherry
>Dan,
Having air dried my share of cherry, I can anticipate that you may have some difficulty.
First, supporting the boards. Your supports should be not more than 12" oc so your rafters, spaced at 16 or 24" wil let the boards sag. not good.
Second, Cherry's dance. This wood needs a dead flat surface and lots of weight to control the movement as cherry dries. I used continuous 4" solid concrete block to hold my stacks. That's 160 lbs of weight for each single-board stack. I don't know what your rafters are made of, but you best check to make sure they can handle that much weight.
BTW your HAVE sealed your board ends very well right?
Yup . . .
steve mackay
>But, here in El Paso during the summer the garage area up in the rafters is set to, roughly, London Broil !
an excellent location, after a bit
Bill Tindall, E.TN
>The rafter area will be a great place to finish drying the lumber but the drying rate may be too fast to put fresh millled lumber up there.
I have had 400 feet of quartered poplar on the slab in front of the garage since last fall and it is headed to the rafters as soon as I can get around to it. It will be 5% MC by July and down it will come and into the rack.
PS there are millions of bdft of lumber dried on 16" centers. I have dried a lot myself on 2' centers and indeed there are commercial operations that use a 1' spacing.
Dan Collins
>Thanks guys. I decided to stack the cherry on the garage floor for now. It is stickered at about 12 inches and I put 4 big rocks on top of the pile. I also sealed the ends.
more rocks
Bill Tindall, E.TN
>Put a layer of anything on top so the top does not dry faster than any other part-sheet of plywood, junk lumber, etc. - and add more weight. Ideally you will have your best lumber buried in the interior of this pile and the worst on top.
Re: more rocks
Paul Waddle
>Haint theer no kilns nearby? You've put a lot of effort in gathering the cherry so don't be too conserative now, and you will have a positive result. pw
Dale Lenz
Dale Lenz
>I put enough weight on my tin lumber covering to hold it down against the wind. On my 10' X 4' pile I believe I have 4-6 cinder blocks, works fine. The rule of thumb,( probably someone Master Thesis or the FPL research) it take something like 150#/sq.ft of weight. So for my wood pile I'd need 40' x 150#/sq/ft. = 6000#, I've got other things to do, and like I said, my lumber turns out fine.
I would suggest has other's have said, treat for bugs and seal the ends of the lumber, I use paint.
Enjoy,
Dale
