>I keep experiencing a circumstance where when I open a message, the message appears for only a second or so and then disappears. I'm too old to develop speed reading, so is there some way to address this? It's been happening intermittently every couple of days the past week or so.
>This has been happening to me also for the last several weeks. You can hold down your left mouse button and "highlight" the area where the message should and you will be able to see it.
It seems to me that it only happens on my PC with IE6 on it. The other PC has Mozilla and it doesn't seem to be happening there.
It is almost like the text color is getting changed to the same as the background color.
>As mentioned, if you highlight the text by holding down the left mouse button and sweeping over the message, you will be able to see it. Still trying to figure out exactly what is doing it. It is a function of Internet Explorer and doesn't happen in other browsers. (Opera, Firefox, Mozilla etc.) I know that Ellis is still working to figure it out, but IE is notorious for not being compliant to the web standards. If you look at the page source for most modern websites, you find that there are hacks in it to make it work with IE and normal web page code for everyone else in the world.
>...with that workaround, but your mailbox refused my e-mail twice. I don't know if you can tell them it's okay to accept mail from me. My mail is all sent from a domain called fast.net.
And, yes, this is a known issue that I have spent way too much time and agonizing over. It is fallout from our redesign back in November. I have to find a much smarter programmer than I to fix it. If anyone is a Perl/CSS guru who understands positioning, please e-mail me.
Meanwhile, FWIW, Firefox is a wonderful alternative to IE6. That's your easiest workaround, but the click and drag trick works, too.
>I use IE6 and had the same problem. The boards returned to normal when I went to the "set preferences" tab and reset everything. Try it. It might work for you too.
