round table apron
round table apron
round table apron
David Ragan
>Hello,
I'm a novice woodworker with some nice equipment; my shop is outfitted, now I've got to actually make something. I want to make my wife a small lamp table-the picture was in a magazine and it has an apron, about two inches high running round, recessed under the round top. My question is about making the apron.
The lamination and steam bending seems a little involved, so I was looking in Tage Frid's book and he "bricklays" pieces-making a round form, then cuts the circle at the bandsaw usine a large jig. My friend (Mr. Mechanical) says that I/we should use a router on a jig to cut the circle out of the wooden bricklayed piece.
The router sounds like the "cleanest" way to do it, but there's no bit 2" long to cut that deep. Anyone have a better idea?
"Thanks for sharing"
David
Re: round table apron
Sure there are
>You shouldn't have any trouble finding a 1/2" carbide straight bit with a 2" flute. Routerbits.com, one of our major sponsors, sells them with cutting lengths up to 2 1/2". Other suppliers do as well.
I'm wondering if you are planning on veneering the apron.
Should be a fun project. Keep us posted.
Ellis Walentine, Host
bricks are part of the solution
Bill Tindall, E.TN
>This technique is used as a substrate for veneer. So, were you planning on veneering the piece after you laid the bricks? Just bricks is going to look like, well, bricks. Novel but not likely attractive. Bricks plus veneer is the way most would make this table.
Bent laminations are really very easy to do. And, you can cut many close spaced kerfs on the back side of a board and simply bend it.
Re: bricks are part of the solution
David Ragan
>Thanks for your responses. What type of wood is best to make the apron from? I have plenty of hard maple, but I understand veneers are difficult to adhere to it. I also have plenty of pine, ie, the kind that Lowe's carries for 2 by 4s. But, am going to the lumber yard this weekend and can get about anything.
I feel more confident about my ability to do the bricklay and then a strip of veneer than the laminations and/or kerf cutting and bending.
Thanks again David
Couple insights for you
>First, hard maple shouldn't pose any adhesion problems with the glues you're likely to be using. That said, you don't need a dense wood like that for your bricklaid apron. Poplar or sweetgum or alder would be fine for something like this. Also, the big box stores don't sell pine as 2x4s. They sell Eastern white pine as S4S lumber, but it is not the wood of choice for your project. I'd grab some cheap poplar from the local mill or yard and make it out of that.
