>For my 1/2" collet, I've got a 1/4", a couple of 1/2", a 3/4" and a 23/32".
Do I really need a 25/32" and a 3/8"? I've been setting my jig "wide" and making multiple passes for the odd sizes like 25/32" and 7/8".
The reason I'm asking is that the place where I often get router bits is having a "sale". I haven't really had much need for the odd sizes, so I never thought about getting them - until I saw the "sale" was on.
Re: So, how many straight router bits do you have?
>Good Afternoon JL,
I bought a Jesada straight set way back in the Badger Pond Days, and these include the 1/4, 3/8, 1/2, and 5/8 bits, as well as a 3/4" and 1 inch. I also bought the a set of undersized plywood bits. These are all 1/2inch shafted tools. I have other straights in 1/4" shanks. Frankly I hardly ever use those over 1/2". I'm glad I have them--just in case. Go ahead and take advantage of the sale, and any over capacity in your bit storage. If you miss the opportunity, it will nag you forever through sleepless nights and deep depression.... Peace of mind is cheap at the price. :<)
George
John_in_Az
>What have you saved if you buy a bit and never use it again, or rarely? If you don't have a particular bit and find you need it all the time, definately buy it. John
Thomas Skaggs
>Nothing wrong with straight bits, I have a few. But I now have a set of upcut spiral bits and they are my "go to" bits rather than the straights. In case you ever make that move too you might not want to be overly invested in straight bits. Food for thought.
Tom
>The router bit manufacturers produce a lot of bits designed to give you a perfect fit for typical plywood thicknesses. There are a couple ways to look at this situation...
First, you can completely house all plywood and related panel products in grooves of that exact size, if you're willing to buy all the possible bits.
Second, and probably smarter, you can rout all your grooves at a standard width, say 3/8", and just cut a rabbet on the underside of your shelf that makes the tongue exactly 3/8" (or maybe a little less for assembly reasons).
Of all the cabinets we ever made -- and that would be quite a few -- I never used an off-size router bit, unless it was for reasons other than fitting shelves or cabinet parts. I am a believer in standard fits and modifying the "shelf" member to fit the program.
Ellis Walentine, HOst
Jesse Cloud
>I hear you John, and I admit to having some underused bits. On the other hand, its late Sunday afternoon and a couple gallons of gas to a store with a decent selection of bits. So I'll probably waste an hour jigging up some workaround and not be happy with the outcome. When I start a project, I get any router bit I think I might need just to avoid that situation.
I hate taking two passes (twice the likelihood of making a mistake). It also doesn't help that I often have to work in metric.
So, I probably have a dozen straight bits if you include flush trims.
Ray Newman
>I have probably too many straight bits & end mills of varying diameters, but that is because I can never find the bit that I need when I need it.
I think it is one of the unwritten laws of woodworking that you never find the bit you are looking for until after you bought another bit & used it....
Jay St. Peter - SoMD
>I agree with Ellis above with one exception. I use my undersize 1/4" bit pretty often. Otherwise I could probably get by with just a 1/4 and 1/2 (occasionally 1/8). Pattern and flush bits in 1/2 and 3/4 with multiple lengths in 1/2 pattern.
Jay
Larry Clinton At Frankfort (Central)., Indiana
>Way too many, I am a sucker for auctions, usually Estate type. I can't pass up a selection of good router bits - (or other quality tools) when a dozen or so sell for the price of one bit. I have several Whiteside. Amana, Frued, etc. that I purchased that way. I also have a full set of Whiteside for the Leigh jig that I purchased new. As far as odd sized, I probably have some but haven't used them as I fit the shelf to the slot. When I made my shop cabinets I did set up my Unisaw with a Dado and cut the slots to size - I made (as I recall about 17 wall cabinets for the shop (about 60 running foot) and the saw was much faster for all the joints. Don't think I would buy new "odd sized" bits to fit the plywood, it's easier and more accurate to make the edge of the mating part a standard thickness. Besides I have had much of the "shop grade" birch ply vary by .010 to .015" from one end to the other - milling the edge provides a much better fit.
