>I suppose this isn't completely OT. I have mistakenly agreed to gut and renovate our master bathroom and now Sweetie Pie will be holding me to it! There will be plenty of woodworking to do...that's for sure.
So I want to upgrade the tub to a jetted tub. No, not one of those big honkin' spa tubs...not enough real estate for one. More of a generous "standard size" tub.
I'm looking a Jacuzzi brand and they have a model that looks good. So does anyone have Jacuzzi brand? Satisfied customers? I've also looked at Kohler. So any insight here or words of advice?
>Be sure whatever jetting system you get has a pump that pumps the tub water to get the jetting action. I once had a motel that had a dozen tubs that used air pumps to create the jetting. Pumps were loud and the air lowered the water temperature very quickly.
>I have a Jacuzzi brand tub in my master bath. It is a large (2 person) so this might not be the perfect comparison for you. It is about 4 years old and have been using it the past 2 years (took me two years to get it installed (not the tubs fault:) I am very happy with the quality and features and I have had no problems with it. We have a heater in ours that is suppose to only maintain the water temp. but it accually will increase the temp while the tub is running. I have the heater on its own switch so we can turn it on and off. The only neg. is the noise, ours runs the water through the pump but it is still noisier than I would like. I am going to add some insulation of some type around the pump area to see if that helps but it has not been a big enough problem to motivate me to do it yet so must not be that bad. Dave
You must be more carefull what you agree to do! You are an artist now and should not be diverting time from your craft! Just sell an extra table or something and pay a lesser mortal to do the work!!
I don't know what planet you just came from but here on earth we upstart furniture guys might better fit the description of "starving artists"! Check back with me in 10 years and see if I'm making a living at it by then. ;-)
I'm afraid that the expectations are high and the budget is low. That's another way of saying that I'll be doing just about everything.
But hey, the Government is sending me $1,200. That ought to pay for a first class bathroom....right?
>Thomas, most of the jetted tubs are really loud making a relaxing moment less than peaceful. I have seen tubs with the pump remotely mounted from the tub (not sure that it was intended to be that way or if the installer just cut it out and did it). This made the tub much quieter although the garage what was under the tub and got the pump was a bit noisy. By all means get the heater, you will drain much of your hot water filling the tub and you don't want to be adding hot to keep the temp up. Some of the two person tubs are really one fat guy tubs, but for two small or normal people it can be rather cosy and you might want to consider it, as I recall they really are only wider and not longer than the other ones. If you put your fill spout on the long wall two people fit better too. Remember when you install it, most have support points beside the rim and they do need to be supported there. Some installers use a dense rubber to isolate the vibration of the pump from the house at all the tub contact points. I think horse stall pads (used on concrete under foot) cut up were used on the ones I saw.
Even if you don't use the jets much the deeper tube is great for relaxing and can completely soak your book when you fall asleep.
You may want to install the tub first so you can spa away all thosr aches and pains from remodeling the bath (g)
>You might want to check out some other people's thoughts on jetted tubs. I did some research when I built my house about 5 years ago, and found out that a lot of people with whirlpool tubs seldom used them, and if not maintained regularly, there can be a problem with mold, leaking seals, etc. I decided to put a "normal" tub in instead. This link is to a home forum that's pretty good and has a lot of different topics. You may find some other helpful stuff too.
>I'm a Home Inspector and have been seeing these tubs for about fifteen or twenty years. I used to ask the sellers how much they liked them. They were almost universally enthusiastic about them. Then I would ask, how often do you use it? The usual answer was "Uhh, twice." I have only met one or two people that used them with any regularity. One or two of them regularly let the grand kids come over and play in it.
I have had about five of these go really badly during the inspections. I have come to the point I will not start them without specific permission and am considering getting that in writing. Brand new ones have emptied their contents down through the house. Locally, many of them are sealed or installed on a platform that has no access doors. (Doors are required, but builders often install them with ceramic tile around them and claim that when the time comes, "you just cut out the appropriate section of tile." My opinion is that a door that is not a door, is not a door.)
So my point is, Don't do it. Put in a soaking tub, but not a jetted one.
Also, the mold thing is very real. Several times a year I turn one on that has not been used in a while and it appears to.... well, hurl. Really nasty. That alone would end my use of the tub.
And, If you do, in spite of my protestations, put in one that has a heater. Also be sure the surrounding area is water proof. These things spatter water everywhere. And don't use oils or bubble bath in one unless you are trying to foam the runway.
>We have a Jacuzzi jetted tub and love it. Even so, we use it maybe once a month. I do feel guilty about using all that water (have to fill it above the level of the jets), but it is incredibily relaxing. Save a few $$ for a bottle of wine to go with that soak.
>I wholeheartedly endorse the idea of getting the water heater with the tub. The circulating water will cool quickly if not keeped up to temperature by the heater.
>When I first entered a jetted bathtub in a Japanese bathtub in Kokura, Japan. I think they injected steam into the water through the jets. Boy was that hot. But got a lot hotter when a young Japanese lady came to the tub, disrobed and sat in the tub with me. Had to sit there, slowly boiling to death till she left the tub and the room. And they didn't have cold showers at that hotel either.
>Thomas Skaggs, yes the "govt." is sending out checks to almost all of the citizens over the next three months. But remember this....that money you receive is going to be considered as income to you and you will have to pay taxes on it next year.
>My folks built a house around 1980, and had a jetted Japanese style tub installed, one where you sit up, rather than lay down. They used it regularly, as did we, and enjoyed it quite a bit. The leakage they had was where most tubs have challenges, at the top, and those were maintained in the way that you have to maintain every system.
That place was sold about 1992, when they moved to the hills, and put a hot tub on the back porch. That still gets used, probably 4 times a week.
We'd have one here, if there were room. Our backyard tub, however, was a waste of the money I spent to put it in. We never could get the water to warm up right. But that's another story, and likely my fault...
I like the professional installer recommendation for many reasons.
