Hanging Lamp w/Toggle Bolt in Drywall Ceiling
Joe Pack
>I need to hang a lamp in the corner of a bedroom ceiling. It will be a swag chain type mount, with electricity coming from an already installed outlet. My original plan was to use a heavy hanging hook screwed directly into the joist, with the chain holding the lamp buy, with my typical luck, the trusses are either 1' or 3' from the wall. I need to hang it somewhere between 24-28 inches from the wall(s) to center it on the corner and make it look right. There is no reasonable way to get a solid mounting block above the drywall (heavily insulated attic above).
The lamp weighs10 pounds. The hanging hook came supplied with both a wood screw mount and a butterfly type toggle. In theory the toggle will work, but I have zero experience with using them in overhead drywall (1/2" thick). Is 1/2" thick drywall sturdy enough to support a 10 pound load held up by a 2" long toggle?
Re: Hanging Lamp w/Toggle Bolt in Drywall Ceiling
Howard Norman
>I have done that several times in the past. I never had any problems with any of the lights that I have installed that way.
h
Steven Antonucci
If you need piece of mind...
steve antonucci
>Take a small off cut of drywall and mount it in your vise. Drill a small hole near the bottom where it is supported by the vise and insert the toggle bolt with an eye bolt. Attach a fishing scale and pull 10# to see if it pulls through.
I'm betting that the burst strength of drywall is much higher than 10lbs/sq in...
Steven
Re: Hanging Lamp w/Toggle Bolt in Drywall Ceiling *LINK*
Curly Smith
>The link lists the failure limits of the toggle/drywall installation. You'll be well under the recommended load limit (safety factor of 4) with your lamp.
Load Capacities in Gypsum Wallboard
Alan Young
With a bit more effort
Alan Young
>Head off to your local Home center borg. Buy a ready milled architectural plate of your choosing. Paint/stain to match or complement your rooms' trim. Or make your own from scraps lying around the shop.
Mount this piece to the ceiling via the toggle screws-(2 inches should be plenty) Then put a hook/screw to this piece and hang the light.
This disk-or what every shape you choose will certainly distribute the weight well over the drywall...
It's probably overkill. But why run a mile when you can run 2? Ha Ha!
Alan
Stronger than I thought
Joe Pack
>Thanks all. Drywall is stronger than I thought!
I'm glad I didn't install the light today like I had planned. I was waiting for responses from you. If I HAD gone ahead without waiting for your opinions, I would have hung the lamp in the wrong spot! Seems my sweetheart changed her mind, and, of course, changed MY mind, on the best location.
I sometimes feel like the guy who said his wife does all the driving when they go places. All he does is hold the steering wheel! :-)
Thanks again for the input.
Re: Stronger than I thought
tek-Brunswick, Ohio
>Just make sure that you drill the hole for your toggle bolt. Some people just punch the hole in with a hammer and screw driver. Punching the hole in makes a cone shaped hole. The hole is small on the side you see, but much larger on the back. That greatly reduces the holding power. A properly installed toggle should easily hold a 10 lb light. That is unless you have Gremlins swinging on it.
Joseph Mulherin, Sr.
>Joe Pack, now you have experienced the one thing about women in building and construction....they basically do not understand, and cannot foresee how it will be finished before the project is finished by you.
BUT, remember this.....SWMBO....She Who Must Be Obeyed.
