Dewalt 18 volt XRP batteries
Terry Alexander
>Fellow woodworkers,
I have 2 of these batteries. One of them charges in < 5 minutes, but doesn't run but about 10 minutes. The other one takes about 30 minutes to charge and it will run HARD for almost 30 minutes. Batteries are identical and relatively the same age.
Is there a "trick" to get the "bad" battery to fully charge? (I think it is faking out the charger).
ANy assistance would be greatly appreciated.
Terry Alexander - Finally in Jones County, TX for good!
Re: Dewalt 18 volt XRP batteries
Re: Dewalt 18 volt XRP batteries *LINK*
Ken Garlock, Collin County Texas
>Good Morning Terry.
It is my guess that one of the individual cells in the battery has gone bad. I would contact Jason Abel at MTO Battery. Jason is the owner and a fellow woodworker. I had a pair of 12V DeWalt batteries rebuilt by Jason, at the price of a single battery from DeWalt. He does good work....
Happy saw dust,
Ken
MTO Battery
Curly Smith
>First, I assume the charge light isn't flashing the "bad cell" signal?
Next, I'll toss out a few possibilities:
- The battery has reached it's useful life. NiCd batteries typically have a 400-500 cycle life.
- You shortened the battery's life by draining the cell too deeply.
- You exposed the battery to high temps and shortened the life.
- You left it in the charger for an extended period after it had been fully charged and the battery developed a "memory". I think this is what you're assuming so I'll provide more info:
"Do NiCd batteries really have a memory effect?
Answering this question is a sure way to start a flame war on the internet. The simple answer is: Technically speaking NiCd batteries do not have a memory effect. However, they do suffer from a voltage depletion or voltage depression phenomenon that most people call the memory effect. So practically speaking, NiCd batteries do suffer from a memory effect, even if it is not technically correct to call it that. There is a lot of disagreement in the battery industry over what actually causes voltage depression. The phenomenon itself is very real. If a NiCd battery is repeatedly charged after it has only been partially discharged it will develop a lower voltage and a lower capacity. Fortunately, this effect is reversible by conditioning NiCds. Conditioning is simply fully discharging the battery (down to about 1.0 V per cell) after charging it. If a full discharge followed by a charge cycle is done several times, a battery suffering from voltage depletion (voltage depression, memory effect, or whatever you would like to call it) should be restored back to its normal voltage and capacity.
If you use NiCd batteries you should be aware that most of the problems experienced by NiCd battery users are not due to a "memory effect" but are due to overcharging or improper storage. Overcharging is usually caused by poorly designed first generation battery chargers. These chargers continue to deliver current to the batteries even after the batteries are full charged. "5- hour" and "8-hour" timer type chargers can damage NiCd or NiMH batteries if they are frequently used to charge batteries that are only partially discharged." (more info at the url)
Do an internet search on "NiCd Voltage Depression OR Depletion" for more info on the phenomena. There's an internet site that purports to tell you how to rejuvenate your NiCd, for a fee, but I'm reasonably sure it's the same technique as described above.
Worst case, take it to Batteries Plus, or an alternative repair facility, and get the cells replaced. I think repair is around $50-60, complete new battery is $100.
jerryburns
>Curly Dewalt had a recall on some 18 volt xrp batterys about 6-8 mounths ago I Had the info at work but I got rid of it two weeks ago during the grate email purge at work damm IT guys wanting storage back
