Keeping bark on Birch
jeff
>Hi all
Last year I made up a batch of display stands from Birch logs.
The Birch bark is seperating from the logs.
2 questions:
Any simple way to keep the bark attached if I re-build them?
Or, should I epoxy glue the bark back on (with maybe a few tacks), and is there any easy way here.
I'd hate to be re-building them each year.
Jeff
Re: Keeping bark on Birch
Try yellow birch
>For some reason, I think that yellow birch retains its bark and white birch doesn't. I recall a friend's cabin in Quebec that was furnished with beds and settees and chairs made of yellow birch logs and sticks, and the bark was intact after decades of use. I'd like to find out the real scoop.
Ellis Walentine, Host
Re: Try yellow birch
Don Orr
>You're right as usual Ellis, yellow Birch will keep it's bark better than white Birch, especially if it is winter cut. White Birch shrinks a lot more than yellow and actually shrinks away from the bark. That's why most Adirondack style furniture made from Birch twigs and logs is made from winter cut yellow Birch. Yellow Birch also looks real nice when varnished and white Birch does not.
Where do you get it?
jeff
>I don't even know if I can find it here in Vermont.
