Sorta OT: Engineered flooring level?
Bill Howatt
>Hi,
I am putting down engineered flooring (3/8"ply with 1/8 hardwood). The spec is floor level to about 1/8 over 10'. My floor was greatly out-of-kilter but I have fixed the worst of it but am struggling with the last bit. I have never done anything like this before.
Regarding the little dips along my straight-edge - just how close does it really have to be so I don't notice it when walking on it and the joints aren't going to fail prematurely. There will be a thin (about 5/32 or so) rubber mat underneath it.
When you are laying it, can you tell it it isn't right because of a levelling problem or is it only when it is all down and you walk on it?
Thanks,
Bill, who thinks carpets are a good idea.
Re: Sorta OT: Engineered flooring level?
Jim in Burlington Ont.
Perfectly flat floor
>There aren't any perfectly flat floors. I really prefer to lay down a layer of tar paper to help level things out. It helps cushion the floor and even things out. Keeps the squeeks down also. Belt sander is a handy tool to have to knock the ocassional high spot down when doing floor prep. Worry more about nails that are high they will show thru horribly later on.
