Saw Blade Stabilizer
>Good Morning Friends,
I had been using the thin kerf Forrest Woodworker II on my Jet contractor's saw w/o a stabilizer and had very good results. I sent the blade to Forrest to be resharpened and tested. When it was returned I had acquired a new Jet hybrid saw, and was then using a Leitz 40 tooth combination blade. When I swapped it out to install the Forrest I noticed a slight wobble in the Forrest which did not occur on the other saw. I can hear the wobble if I shut the saw down in mid cut. The wobble is also clearly visable as the saw spins down to a stop. There is no wobble with any other blades on the hybrid. I noticed the arbor washer is of a lesser diameter on the hybrid than it was on the old contractor saw, and theorize the larger washer on the old saw acted as an effective stabilizer. There does not appear to be any arbor shaft runout to speak of, as all my other Freud abnd Leitz blades run true. I think I better get a stabilizer for the Forrest WWII. Comments? Thanks.
George
