Removing cosmoline..what's the best way?
Alan Young
>I have a fairly major amount of this stuff on a recent acquisition. Any suggestions are appreciated.
Alan
Alan Young
Alan
Kerosene
Lee Schierer - McKean, PA
>Kerosene and lots of it will cut the cosmoline. Be sure to do this in a well ventilated area and to hang the rags out to air dry when you are done. You will need lots of rags. Remove the oil from the keorsene with mineral spirits.
Be sure to apply T-9 and or paste wax as soon as you remove the oil from the kerosene or your exposed cast iron will start to rust.
Lee
Re: Removing cosmoline..what's the best way?
Carl
>I always use Brakeclean all the time works great just make sure you are outside.
Howard Norman
>I would second the use of Kerosene to remove cosmoline.
WD 4-. The very best preservative remover.
Forrest Addy
>Any petroleum solvent will work to soften and remove thick waxy films of metal preservative including kerosene, mineral spirits paint remover, lighter fluid, etc. If it's soft use a plastic scraper or putty knife to remove the bulk by simply scraping. Dump the goo in an old carboard box. If the perservative is firm, spray it down with solvent and allow the preservative to soften. Then brush it with a coarse plastic brush to form a soft goo then wipe it off.
It may take serveral cleaning cycles if the preservative is resistant but perseverance will win the day and your new toy will be spandy clean.
sounds like a poorly disguised gloat
Robin Corell in Atascadero, CA
Re: Back in the good 'ol days.......
Jesper, Denmark
>In the service, the best way to remove cosmoline was a six pack to the armory sargent before he dunked your M1 Garand into the tank after inspection.
Like the saying goes." an ounce of prevention...." But that does not really address your situation.
Gloat ? Moi? Well, yup :^)
Alan Young
>Here it is. Eat your hearts out .....Hah Hah
Alan (I'll give a fuller report when it's ready)
Re: Kerosene
Howard Acheson
>The reason many will recommend kerosene as a cosmoline remover is that kerosene leaves a slight oily residue which acts as a rust preventer on those parts that many not get waxed or treated. Kerosene cuts the gunk easily and it's slow evaporation means it will stay on the surface until you wipe it off. It's also less flammable than mineral spirits, naphtha and other higher order petroleum products
