finish for ash
finish for ash
finish for ash
Bill Tindall, E.TN
>Ash is hard to finish. Many finishes yellow with age and yellowing on the whiteness of ash looks gross (IMO). I have been spraying a "water white" conversion varnish (Sherwin Williams) but even it yellows some.
What is available in the water based finishes that can be sprayed? I must admit that I tried a water based finish several years ago and was disgusted by the blue haze and the difficulty of spraying something with the viscous properties of water. Its only benefit was that it has not yellowed.
I can believe that things may have improved and I will try a recommendation if someone has a knowledgeable one. The finish must not yellow with age, it must be bright like a nitrocellulose lacquer and be practical to spray. Bottom line, can I get nonyellowing without giving up the desirable properties of solvent finsih?
Re: finish for ash
Re: finish for ash
Lee Schierer - McKean, PA
>I've noticed that the water borne finishes tend to yellow considerably less than solvent based finishes. Deft Clear wood finish also yellows less than Polyurethane.
Lee
Re: finish for ash
Tried bleaching?
>I built a dining room once where the designer specifically called for bleached ash. We used two-part bleach (sodium hydroxide/hydrogen peroxide) and topcoated with water-white solvent-based lacquer. It really came out nice and held its neutral lightness over time.
I have been using Velvit AquaShield water-borne polyurethane and like it very much. I would suggest trying it. You may decide you prefer it to NC lacquer.
Re: finish for ash
Target WB Finishes *LINK*
mdclor
>You might consider Target's 9000 SuperClear Polyurethane.
Oxford 9000
Re: finish for ash
Re: finish for ash
>At the risk of beating a dead horse, unless there's an overiding reason not to use it, the most permanently water white finish I've found is solvent based acrylic or alkyd lacquer. IMO, the Sherwin williams formulations cannot be beat.
Clint
Re: finish for ash
Where do you get it?
>I looked up the Velvit AquaShield and it appears to have very limited distribution. Who carries it?
Lee
Re: finish for ash
what is the product name
Bill Tindall, E.TN
>I have not seen anything in the local store that matches your description. They will order for me, or I can get stuff from a branch that more caters to furniture trade, but I need to be sure what to ask for.
Re: finish for ash
Re: what is the product name
>DESCRIPTION
SHER-W00D� CAB-Acrylic Lacquer is formulated
to meet the water white and nonyellowing
demands of the furniture, kitchen
cabinet, and wood finishing markets. It is intended
as a clear topcoat over white, �pickled�
or light pastel stains where the best nonyellowing
properties are required. Cellulose
Acetate Butyrate (CAB)-Acrylic presents the
best chemistry of lacquers for resistance to
yellowing.
Advantages:
� Meets the federal HAPS rule for wood products
as packaged*
� Water-white color
� Excellent resistance to yellowing - superior
to all nitrocellulose compositions
� Meets KCMA specifications when applied
over Sher-Wood Vinyl Sealer T67F3, T67F5,
T67F6 or T67F7
� VOC under 5.6 lb/gal**
� Fast drying - similar to nitrocellulose lacquers
� May be used directly over solid color lacquers
as a �scuff coat�
� Excellent film clarity and color retention
� Application by conventional, airless or air
assisted airless spray equipment
� Excellent print resistance after overnight
dry
� May be used as a shading lacquer or toner
by adding small quantities of Chroma Chem
844 colorants
� Free of lead hazards as packaged in compliance
with Consumer Product Safety
Commission's (CPSC) 16 CFR Chapter II:
Subchapter B, part 1303.
CHARACTERISTICS
Gloss(measured on black glass):
Gloss 85+ units
BRE 55-59 units
MRE 30-34 units
DRE 17-21 units
Volume Solids: 19.2 � 1%
Viscosity:
26-32 seconds#2 Zahn Cup
23-26 seconds#4 Ford Cup
Recommended film thickness:
Mils Wet 4.5 - 6.0
Mils Dry 0.7 - 1.0
Spreading Rate (no application loss)
310-443 sq. ft./gal. @ 0.7-1.0 mil dft
Drying (77�F, 50% RH):
To Touch: 10 minutes
To Handle: 15-20 minutes
To Sand: 30-60 minutes
To Recoat: 30-60 minutes
Force Dry: 10-20 minutes at
110-140�F
Flash Point: 37�F Pensky-Martens
Closed Cup
Package Life: 18 months, unopened
Air Quality Data:
Non-photochemically reactive
Volatile Organic Compounds (VOC)
as packaged, maximum
5.60 lb/gal, 672 g/L
3.20 lbs VOC/lb solids
Hazardous Air Pollutants (HAPS)
as packaged,
less than 0.8 lbs per pound of solids
An Environmental Data Sheet is available
from your local Sherwin-Williams facility.
CC-F23 10/07 continued on back
SPECIFICATIONS
Wood (interior only): Must be clean, dry,
and finish sanded. Substrate should be
free of grease, oil, dirt, fingerprints, and
any contamination to ensure optimum
adhesion and coating performance properties.
Moisture content of wood should be 6 to
8%.
Testing: Due to the wide variety of substrates,
surface preparation methods,
application methods, and environments,
the customer should test the complete
system for adhesion and compatibility
prior to full scale application.
Wood Finishing System:
1. Apply full wet coat of Sher-Wood Vinyl
Sanding Sealer, T67F3 or T67F6
2. Air dry 30 minutes, sand, remove all
sanding dust.
3. Apply full wet coat of Sher-Wood CABAcrylic
Lacquer and allow 30-60 minutes
drying.
4. For more depth and better appearance,
apply a second coat.
SHER-WOOD� CAB-Acrylic Lacquer
Gloss ................................... T75C15
Bright Rubbed Effect ............ T75F16
Medium Rubbed Effect ......... T75F17
Dull Rubbed Effect ............... T75F18
*National Standards for Hazardous Air Pollutants
(HAPS) Emissions for Wood Furniture
Manufacturing Operations CFR40, Part 63,
Subpart JJ
CC-F23
Chemical Coatings
**VOC compliance limits vary from state to
state; please consult local Air Quality rules
and regulations.
APPLICATION
Reduction
In high humidity conditions or where
blushing is evident, add 1-2% Butyl
Cellosolve, R6K25, or MAK, R6K30, as
a HAPS compliant alternative.
Typical Setups
Conventional Spray:
Air Pressure ..........................45-65 psi
Fluid Pressure .......................... 6-8 psi
Reducer ....................................... none
Airless Spray:
Pressure ...................... 1200-1800 psi
Tip ........................................ .011-.015"
Reducer...................... . HAPS compliant
lacquer thinner, R7K320 as needed up to
10%. Lacquer thinner, R7K120 may also
be used, but is not HAPS compliant.
Air Assisted Airless:
Air Assist ...............................10-15 psi
Fluid Pressure ................. 400-600 psi
Cap/Tip ................................ .011-.015"
Reducer ..........................HAPS compliant
10%. Lacquer thinner, K120 may also be
Cleanup:
Clean tools/equipment immediately after
use with HAPS complying lacquer
thinner, R7K320 or R7K322. Lacquer
thinner K120 or K22 may also be used,
but are not HAPS compliant.
Follow manufacturer's safety recommendations
when using any solvent.
SPECIFICATIONS
Product Limitations:
� Surface to be finished must be free of
grease, dirt, and other foreign matter.
� Sher-Wood Vinyl Sealer, T67F3,
T67F5, T67F6 or T67F7, must be used
as a sealer to meet the KCMA specification.
Do not use any other lacquer
or vinyl sealers under CAB-Acrylic Lacquer.
� Self-sealing systems are not recommended.
� Maximum cure and resistance properties
are not obtained for at least 14
days air drying.
� Yellowing over white and pastel colors
may occur due to the yellowing tendency
of the color system (stain,
basecoat, etc.), and not to the clear
CAB-Acrylic topcoat.
� For interior use only.
� Agitate thoroughly before use.
� To maintain HAPS compliance only
reduce with HAPS compliant reducers.
CAUTIONS
Thoroughly review product label for
safety and cautions prior to using this
product.
A Material Safety Data Sheet is available
Please direct any questions or comments
to your local Sherwin-Williams facility.
LABEL CAUTIONS
CC-F23 SHER-WOOD� CAB-Acrylic Lacquer
Performance Tests:
Wood test panels prepared with one coat Sher-
Wood Vinyl Sealer, T67F3 and two coats Sher-
Wood CAB-Acrylic Lacquer, T75F17 (MRE).
Allowed to ambient age 30 days
Panels tested per KCMA Chemical Resistance
methods.
Household Chemicals Test
Vinegar ............................................ no effect
Lemon Juice ................................... no effect
Orange Juice .................................. no effect
Grape Juice .................................... no effect
Tomato Catsup ............................... no effect
Coffee ............................................. no effect
Olive Oil .......................................... no effect
100 Proof Alcohol ........................... no effect
Water and Detergent, 1% ............... no effect
Mustard (1 hour) ........ very slight discoloring
Cold Check Resistance ................ 20 cycles
Resistance to Discoloration�films cast on
white porcelain and exposed to 200 hours
Mercury vapor sunlamp showed virtually no
yellowing while conventional nitrocellulose lacquer
exhibited substantial yellowing
Note: Product Data Sheets are periodically
updated to reflect new information
relating to the product. It is important that
the customer obtain the most recent
Product Data Sheet for the product being
used. The information, rating, and
opinions stated here pertain to the material
currently offered and represent the results
of tests believed to be reliable. However,
due to variations in customer handling
and methods of application which
are not known or under our control, The
Sherwin-Williams Company cannot make
any warranties as to the end result.
SEE CONTENTS STATEMENT ON LABEL.
Contents are FLAMMABLE. Vapors may cause flash
fires. Keep away from heat, sparks, and open flame.
During use and until all vapors are gone: Keep area
ventilated - Do not smoke - Extinguish all flames,
pilot lights, and heaters - Turn off stoves, electric
tools and appliances, and any other sources of ignition.
VAPOR HARMFUL. Use only with adequate ventilation.
Wear an appropriate properly fitted vapor/particulate
respirator (NIOSH approved) during and after
application, unless air monitoring demonstrates
vapor/mist levels are below applicable limits. Follow
respirator manufacturer�s directions for respirator use.
Avoid contact with eyes and skin. Wash hands after
using. Keep container closed when not in use. Do not
transfer contents to other containers for storage.
FIRST AID: If INHALED: If affected, remove from
exposure. Restore breathing, Keep warm and quiet.
If on SKIN: Wash affected area thoroughly with
soap and water. Remove contaminated clothing.
Launder before re-use. If in EYES: Flush eyes with
large amounts of water for 15 minutes. Get medical
attention. If SWALLOWED: Call Poison Control Center,
hospital emergency room, or physician immediately.
SPILL AND WASTE: Remove all sources of ignition.
Ventilate and remove with inert absorbent. Incinerate
in approved facility. Do not incinerate closed
container. Dispose of in accordance with Federal,
State, and Local regulation regarding pollution.
DELAYED EFFECTS FROM LONG TERM OVEREXPOSURE.
Contains solvents which can cause permanent brain
and nervous system damage. Intentional misuse by
deliberately concentrating and inhaling the contents
can be harmful or fatal.
WARNING: This product contains chemicals known
to the State of California to cause cancer and birth
defects or other reproductive harm.
DO NOT TAKE INTERNALLY. KEEP OUT OF THE
REACH OF CHILDREN.
FOR INDUSTRIAL USE ONLY.
SEE MATERIAL SAFETY DATA SHEET.21363-
051905.SHER-WOOD� CAB-Acrylic Lacquer
DESCRIPTION
SHER-WOOD� Moisture Resistant
Lacquers are self sealing general purpose
topcoats specially designed for resistance
to moisture and household
chemicals.
Advantages:
� Meets the Federal HAPS rule for wood
finishes as packaged*
� Excellent moisture resistance
� Excellent resistance to household
chemicals
� Self sealing
� Non-photochemically reactive
� Excellent adhesion
� Excellent cold check resistance
� Meets the test requirements of KCMA
specifications (See Specifications section)
CHARACTERISTICS
Gloss: Gloss Full
MRE 30-34 units
DRE 17-21 units
Weight Solids: 24 � 1%
Volume Solids: 16 � 2%
Viscosity:
28-33 seconds #2 Zahn Cup
Mils Wet 5.0 - 6.0
Mils Dry 0.8 - 1.0
@ 0.8-1.0 mil dft: 265-331 sq ft/gal
To Touch: 10-15 minutes
To Handle: 30-45 minutes
To Recoat: 60 minutes, do not
exceed 12 hours
Force Dry:
To Sand 10 minutes at 140�F
To Recoat: 15 minutes at 140�F
To Pack: 60 minutes at 140�F
Flash Point: 22�F Pensky-Martens
Closed Cup
Package Life: 3 years, unopened
Air Quality Data:
5.63 lb/gal, 673 g/L
3.17 lbs VOC/lb solids
CC-F7 04/05 continued on back
SPECIFICATIONS
8%.
Three Coat System
1. Moisture Resistant Lacquer, dry one
hour
2. Moisture Resistant Lacquer, dry one
hour, sand with stearated paper
3. Moisture Resistant Lacquer
Sanding Sealer System
1. Vinyl Sanding Sealer, T67F3, T67F5,
T67F6 or T67F7, dry 30 minutes and
sand
hour
The 3 coat system is ideal for customers
who like to limit the number of finishing
materials they must have on hand to one
product.
SHER-WOOD�
Gloss ................................... T70C20
Medium Rubbed Effect ......... T70F22
Dull Rubbed Effect ............... T70F23
Pollutants (HAPS) Emissions for Wood
Furniture Manufacturing Operations
CFR40, Part 63, Subpart JJ
CC-F7
Chemical Coatings
APPLICATION
Typical Setups
Reduction: Normally not required. If reduction
is needed use HAPS Compliant
Lacquer Thinner, R7K320 or R7K322.
Lacquer thinner K22 or K120 may also
be used, but are not HAPS compliant.
May be applied by:
Conventional
Airless Spray
Warm Spray
Curtain Coating
Consult your Sherwin-Williams Representative
for details.
Conventional Spray:
Air Pressure .......................... 50-65 psi
Fluid Pressure ....................... 12-15 psi
Cleanup:
thinner, R7K 320 or R7K322. Lacquer
thinner, K120 or K22, may also be used,
Moisture Resistance Test:
Birch panels were finished with 3 coats of Gloss
Moisture Resistant Lacquer, with 1 hour drying
between coats. The front, back and all sides were
finished.
1. An "X" cut was made through the finish to the
wood. This was covered with a wet synthetic
sponge for 16 hours. After sponge removal, a
whitening appeared, on the cut, which disappeared
after 2 hours.
2. KCMA Finish Test, F-4, Detergent and Water
Test�no effect.
Performance Tests:
Cold Check Resistance .................. 20 cycles
Print Resistance ................................. No print
3.0 mils dft, 18 hours air dry, at 1 psi at 77�F in
direct contact with 8 oz. duck cloth.
Maple panels were finished with 3 coats of Gloss
between coats. After film was aged 30 days at
77�F, 5 drops of each item were placed under a
watch glass for one hour. The film was rinsed
with water, washed with soap and water, dried
and wiped with VM&P Naphtha to remove items
not removed with water. After removal, the finish
was examined and the following results noted:
Household Ammonia .......... slight haze/dulling
Vinegar ................................... no visual effect
Lipstick ................................... no visual effect
Lemon Juice ........................... no visual effect
50% Ethyl Alcohol .................. no visual effect
Mercurochrome 2% ................ no visual effect
Washable Blue Ink ................. no visual effect
Mustard .................................. no visual effect
Oil Base Paint ........................ no visual effect
Latex Emulsion Paint ............. no visual effect
VM&P Naphtha ...................... no visual effect
Turpentine .............................. no visual effect
Orange Crayon ....................... no visual effect
Carbon Tetrachloride .............. no visual effect
Mayonnaise ............................ no visual effect
10% Sodium Carbonate ......... no visual effect
Sour Milk ................................ no visual effect
Margarine ............................... no visual effect
Butter ..................................... no visual effect
Water ..................................... no visual effect
Grease (Cooking fat) .............. no visual effect
CC-F7 SHER-WOOD� Moisture Resistant Lacquer
CAUTIONS
product.
LABELS CAUTIONS
exposure. Restore breathing. Keep warm and quiet.
attention. If SWALLOWED: Do not induce vomiting.
Call Poison Control Center, hospital emergency room,
REACH OF CHILDREN.
SEE MATERIAL SAFETY DATA SHEET. 21513-
100402.
SPECIFICATIONS
� Surface to be finished must be free from
grease and other foreign matter.
� Apply all coats within a 12 hour period or
lifting may occur.
� Apply directly to bare or stained wood for
best adhesion and moisture results. Adhesion
may be impaired and resistance to
moisture lowered if used over lacquer
sealer. If a sealer is desired use Sher-
Wood Vinyl Sealer, T67F3, T67F5, T67F6
or T67F7.
� If spraying conditions are above 50% RH,
use MAK, R6K30, to prevent wet film blushing.
Such drying conditions will lengthen
time to harden the film.
� Customer urged to pretest system under
shop conditions.
� Sand and remove sanding dust between
each coat.
� Not recommended for exterior use.
� To maintain HAPS compliance only reduce
Re: finish for ash
Oh, CAB lacquer
Bill Tindall, E.TN
>I am familiar with this material. The CAB part is made just down the road from where I live and it is stocked by the local store.
