Need Grass hinge ID and help w/specs (w/pic)
David Eisan
>Hello Everyone,
A friend has a bunch of these Grass hinges he bought a year or so back and never used. I would like to use them on my current garage cabinet project. The problem is that he does not have the specs for these hinges and they are not current, so I cannot find specs for them on the web.
Here are any of the marks I can read off of them,
stamped on the back of the cup, 12/1, 07-01
stamped on the back of the hinge knuckle, 07 01
stamped on the back of the mounting plate, 01 06, 160
stamped on the back of the hinge arm, US PAT 6061872
I would like to know what overlay these hinges are, how many MM from the edge of the door the 35MM cup hole should be drilled and how far back the from the edge of the cabinet the mounting plate should be.
Can anyone help?
Thank you,
David.
Re: Need Grass hinge ID and help w/specs (w/pic)
Dick Coers
>They look like half overlay, cup hole 5mm from edge, cabinet drilling 37 mm from front face. Now that is from memory. If I were you I would take a piece of solid stock and a piece of plywood scrap to check before the build. Not resposible for any mistakes from my declining memory!!!!!!LOL
