Have a question? Ask Woody!
sawing, drillling magents?
Bill Tindall, E.TN
>I keep on hand some of the disk magnets from LV. Can they be sawed ( as in sawed into two half moons) and a hole drilled through the disk?
I have no idea what to expect whether the metal will be hard or soft, but someone on WC has tried everything so I thought I would ask.
Re: sawing, drillling magents?
Dan Donaldson
>They are usually very hard and brittle. More like a ceramic than a metal. Yo might be able to cut one with a high speed grinder and a cutoff wheel, but it could be hazardous to your health and tools. I don't know what yo would run into with the dust. Might get into everything. A carbide drill might be hard enough to drill one, but I would be very careful.
Jim DeLaney, Austintown, Ohio
>Bill,
For the odd shaped magnets, check out some of the vendors on Ebay. I've bought several washer-shaped and cube magnets there.
Jim D.
X-nay on drilling or cutting those,
Eddie Pacheco; San Jose, Ca.
>Unless you have a specialized high speed (10k rpm) diamond saw,or diamond drill. Wire or sinker EDM will work too. Where I worked we used ceramic material similar to those magnets for creating the magnetic heads for the disk drive industry. That's what it took for us to cut that material.
Score with a diamond scribe and breaking may work and maybe one of the tiny diamond drill bits that fit a Dremel type tool.
Please post if you are able to find a homebrew method.
Yikes-Danger, Danger!
Bill Tindall, E.TN
>Drilling seemed to be going fine when suddenly the powder generated by drilling caught afire.
I do not advise drilling unless its under water.
I found a shape suitable in LV catalog and will order what I need.
The curse of the intrepid experimenter :-)
