Burl Elm
Burl Elm
Burl Elm
Jim Hoeller------WebKitFormBoundarycQB+IfmNjFaVxeA
>I was given a large piece of burl elm, about 24" wide at the widest, 8' long and 1/4" thick. It includes sap wood and bark. It needs to be flattened and I need to learn how to to do this (it is still green". Any assistance would be welcome.
Thanks
Re: Burl Elm
Thickness typo?
>Is this slab actually that big and only 1/4" thick? Nah. That must be a typo.
Anyhow, the quick way to flatten it is to take it to your buddy with the cabinet shop and have him do it for you on his 24" jointer. Plan B, if your friend doesn't have a 24" jointer, would be to hand plane one side so it is fairly flat and have your friend run it through his 24" planer. Plan C, if he doesn't have either machine, would be to find a new friend.
The other alternative, if you want to do it yourself, is to make a sled somewhat bigger than the piece of wood, with parallel walls on the long side. Then make a router carrier sled that rides on top of the walls. Chuck a 1 1/2" straight bit in your biggest router and flatten the whole slab by riding the router back and forth in the sled as you travel down the larger sled. We used to reserve this technique for boards that were too wide for our 24" planer.
One thing you might want to think about before you do anything with this slab, though, is the moisture content. Elm is not exactly a well-behaved wood and a burl slab has who-knows-how-many weirdnesses in the grain just waiting to twist or cup or shrink or something. If you can afford to wait until the piece dries before machining it, your odds of a board that stays flat improve dramatically. If you're in a hurry, you could try to rig up a little solar lean-to on your building, or stow it in some warm dry loft for as long as it takes to get the MC down in the useful range, generally between 6 - 10% depending on your locale and the time of year.
If the wood is really 1/4" thick, get someone to put it through a Timesaver to get it down to about 1/8" - 1/10" and then glue it to a piece of plywood or MDF, with a balancing piece of veneer on the other side.
Ellis Walentine, Host
Re: Burl Elm
Re: Burl Elm
Robin Corell in Atascadero, CA
>I have found with green boards up to 2" thick that I can often improve on their flatness by stickering them flat with stickers, a board, and several hundred lbs of weight stacked on top. For something that thin I would place the stickers at least 12" oc, possible even closer.
I would also suggest that you start thinking of how you will cut the slab up to use it in much smaller pieces. That way if it does dry successfully in one piece you will have a pleasant surprise and will not be at a loss of how to use it, but you will also be less disappointed in the more probably outcome. 1/4" slices with the sap wood generally don't behave very well when drying. For 24" wide I never mill at less than 2 1/4", but burl can be unpridictable. it sometimes warps and checks and othertimes it dries perfectly with no degrade.
Robin
Re: Burl Elm
Re: Thickness typo?
Jim Hoeller
>The wood slab is 1/4" thick. I got it from a small, custom sawmill using a Wood Mizer. The owner of the mill where I'd taken some walnut logs to be cut, has one huge elm tree log that is almost all burl. Areas of the inner heart wood that are more normal have what appear to be small leopard spots in tight bunchs. He has cut about 1/2 of the tree so far. I'm not sure why he cut the piece he gave me but I wasn't about to turn in down. I do appreciate the responses.
Re: Burl Elm
Dale Lenz
Re: I'd try this
Dale Lenz
>Believe I would put 3/4" drying sticks every 12"(top and bottom) across your elm "board". Clamp the top and bottom sticks together and lay the elm on some level surface to allow to dry, should be dry in 1-2 months. You will need 18 drying sticks and clamps. Clamps should be the same kind/size and clamped from the same side so you can lay the elm in a non stressed position.
Make sense? ... Dale
Re: Burl Elm
Dale Lenz
Re: Sawmillers....
Dale Lenz
>typically will saw a "sliver slat" off of the log to true the next cut up.
