Plano clamp users?
Plano clamp users?
Plano clamp users?
Dean Lapinel
>Any Plano clamp users that can give a yeah or nay on the long term use of this clamping system? Last review I saw was 1998.
Re: Plano clamp users?
Rick L
Re: Nay on Plano clamp
Rick L
>Been using the curved caul method for 35 years. Perfect alignment. Able to glue up perfect 4' x 8' panels single handed. All I have to do is scrape the glue. I always plane to finish dimension before gluing up as well. Never use biscuits or dowels.
My background is commercial and industrial woodworking so have done panels every way imaginable. Have tried a friends Plano and can't compare to the curved caul method. Curved caul method uses quick clamps and bar clamps you should already have so the initial investemnt is nil to minor.
Too many unnecessary gimmics out there for the novice woodworker. Unlike most woodworkers I prefer to limit my purchase of tools and keep it as sparse as possible.
So...
Dean Lapinel
>I use the curved caul method to glue shelves into their dados. You use these cauls on top and below the panel glue up to keep the boards in line while you edge clamp with regular clamps? I used to use biscuits then lately I use clamps in both directions and slap the misbehaving board with my rubber mallet.
Do you have a pic of your approach? What I visualize seems cumbersome.
Rick L
Re: Not cumbersome...
Rick L
>It's basically a very old technique for gluing veneers minus the plywood pressure boards. I use an 1/8" crown on four foot cauls. I use 2 beams to place the bottom row of cauls on to give clamp clearance. I could set it up to work like the Plano. The Plano falls short because of the lack of curve on the beams. I never use biscuits or have to tap the boards in place. I do take a few more minutes to mill the wood properly instead of relying on having a bigger planer to tweak the panel. Kind of like fixing the barndoor after the horse got away. I only need a planer as big as the jointer. It's not cumbersome at all. I do my panels single handed and very leisurely. It's not a mad dash at all.
Dean Lapinel
>I'm sorry for having to ask for more information but this is a technique that I have not used for flat panels.
So you use two four foot cauls to keep the boards flat and as many clamps as needed to keep preesure on the edges right? I assume then that you also use four clamps on the two cauls, correct?
Rick L
Re: It's real simple...
Rick L
>Start with two beams or doubled up 2 x 4's to support the cauls. Cauls are in pairs, perpindicular to the beams, curves facing each other, top and bottom. spaced about 12" to 16" apart for each pair.
A pair of clamps for each set of cauls. Clamp the cauls lightly, then put on the bar clamps. Tighten the caul clamps some more then tighten the bar clamps more. If it is cumbersome then you are doing sometning wrong. You can stack the boards and brush the glue on or come up with whatever works for you. I glue the entire panel at once. No need to glue up a panel in several pieces. Just do it! I find having a master caul to copy from works best. Having different cauls could introduce twist. It's not rocket science. It's basically a Plano but Plano never finished designing the product.
