Vacuum Pump
Vacuum Pump
Vacuum Pump
Tim in SE Michigan
>Anyone ever use a Venturi Vacuum pump before? They seem cheaper than a true vacuum pump but does that come at a cost of performance. I have a 5 hp 60 gallon compressor so that should be able to handle the input needed for the ventur pump.
Thanks in advance.
Tim
Re: Vacuum Pump
Re: Vacuum Pump
Eddie Pacheco; San Jose, Ca.
>Yes, I've used them before on pick and place machines. They are good for that and if you have no or minimal leaks. Your compressor will be running a lot on a long duration holding project. If used for a router jig, make sure to really get a really good seal on your part, cause a leak will allow your part to go flying.
Re: Vacuum Pump
Re: Vacuum Pump
>I've used a variety of vacuum pumps. In one job I had we used a big venturi - it got down to maybe 20" of Hg. The problem is, the compressor had to run pretty much most of the time when we used it.
You may want to consider other alternatives - like a small Gast pump (look on Ebay).
Re: Vacuum Pump
Re: Vacuum Pump
Howard Norman
>I have never seen a venture system that was able to achieve a good vacuum. I wouldn't use one myself.
h
Re: Vacuum Pump
Re: Vacuum Pump
>Some of the new venturi systems work pretty well but they have 2 big drawbacks. Noise and being an air hog. I bought a used compressor at the flea mkt for $35 and it runs quiet off of electricity and will go to 23". The only downside. If you get a power outage you lose the vacuum.
Re: Vacuum Pump
Re: Vacuum Pump *LINK*
Tradd
>I built a venturi system with parts and plans from JoeWoodworker.com. It uses PVC tanks and a Mac valve to hold the pressure. I am very happy with it. I am able to do long glue ups and the compressor only runs for about 2 min at the start. Check them out.
http://joewoodworker.com/veneering/v2-parts.htm
Re: Vacuum Pump
Ditto
Grant Smith
>I have no idea what system others were using, but my Joe Woodworker designed venturi system works great. The system is automatic and only uses air when the valve calls for more vacuum. My 110VAC 1.5HP compressor keeps up just fine. I built a tank from 3" PVC and therefore the unit keeps a reserve of vacuum and only cycles if there are leaks in the bag...which you should try to avoid with any system.
Oh, and there's no danger with using PVC, since the tank wouldn't "explode", it would "implode". You can adjust the amount of vacuum the system is set for, which makes it very versatile for various projects.
Regards,
Grant in Iowa
