200+ woodworking book reviews
Making Greene and Greene pegs
Thomas S Stockton
>Bill Tindall asked about making pointy pegs, this is how I do Greene and Greene style ones but mking the pointy is an easy change.
Adding ebony pegs to a piece of furniture is not that hard to do. The first step is to mill up some square stock it is easiest to make a dozen or so lengths so that you can do the steps efficiently. I make it so that it is a fairly tight friction fit into the hole.
Re: Making Greene and Greene pegs
Thomas S Stockton
>I then proceed to square up each end on a disk sander using a very simple jig that rides in the miter slot and has a 90 degree and 45 degree guide block on it.
Thomas S Stockton
>The next step is to put the 45 degree bevel on both ends, I just eyeball it and roll the work so that I can match the previous bevel. If you screw it up just square it up and try again.
I prefer a slight bevel as opposed to a pyramid shape, on the original Greene and Greene pieces the pegs are domed shape. Now is the time to do your shaping and sanding since it is much easier to hold onto a long stick than a little peg.
Thomas S Stockton
>I then proceed to cut the pegs off on the bandsaw. I cut into a piece of wood to make an small auxiliary table. I then proceed to cut off the pegs lightly holding it down with a piece of wood, this keeps it from flinging across the room. I stop using a stick of ebony when it gets to short to cut safely. You could also make a simple miter box and cut them with a handsaw which is probably less intimidating.
If I�m making a bunch of these the next step is to takes the strips and go back to the sander and start over by squaring and beveling. I can easily make 100 in an hour.
Thomas S Stockton------WebKitFormBoundarykeAhJIqQT
>I then put a very slight bevel on the bottom of the peg to help it slide in the hole
Thomas S Stockton
>It is now time to install the pegs I put a little glue on the sides of the hole and tap the peg in until it is just at the bevel. At this point if something is wrong with a peg I just throw them out and choose another one.
Thomas S Stockton
>the finished peg ready to lightly sand
Jesper, Denmark
Jesper, Denmark
>This can go straight to the articles section.
Thomas S Stockton
>If you drive one in to far drill a hole in the middle and drive a screw into it and pull it out with a pair of pliers and try again
Thomas S Stockton
>Jasper
just sent it in
Tom
Thanks, Thomas!
Eddie Pacheco; San Jose, Ca.
>I recently took a class with Darrell Peart and while doing some of these at home, it dawned on me that these pegs cost about $60/peg by the time you finally get them in the hole.
Excellent tutorial, Tom
>You didn't mention how you mortise the holes, though. Do you use a hollow mortising chisel and size the ebony to fit?
Thomas S Stockton
>The next step is to make the hole I use a hollow chisel mortiser it is very quick and easy. There are a couple of other ways to do this one is to use just the chisel from a mortiser.
This is fairly easy just drill a hole with a brad point bit and the chop it square with the bit and a mallet. No need to buy a fancy bit the cheap ones if honed well work just fine.
The last way to do it is to drill a hole a square it up with a chisel. The drawback to this technique is that every hole is a little different and it takes forever to custom fit each peg.
Re: Excellent tutorial, Tom
Thomas S Stockton
>Ellis
I'm glad you caught that I just added it to the sequence, it got spit out the first time by the web kit boundery garbage.
Tom
My little peg polishing jig
>Not in the same ballpark or even the same league as you, Tom. However, I thought I would post the little holder I made so that I could polish my ebony pegs. During a week long Darrell Peart G & G class, I was lagging a bit and I had a bunch of pegs that needed polishing and Darrell had already packed his stuff away for shipment back to Seattle. After trying to finger hold these already cut pegs I came up with this holder and I was able to get my pegs done at home. the peg fits in the sq. hole tightly and the rod is used to push it out when done.
I pegs in place
>Here's a close up view of he pegs in place on what is going to be a G & G elliptical table designed by Darrell Peart. The table is finished, I haven't applied the finish to it yet. Uh, why so many pegs on the leg?
That's the result of a major screw up on my part. The leg is a two piece glue up and I needed to make a mirror image of each half. Well, I didn't get the mirror image part until I was in production mode cutting my mortises and peg hole on each of the pre-glue up blanks. Rather than make a 3rd table (Nancy was making one of her own) I opted for this fix.
The finished table when viewed from afar looks like....an elliptical table with too many ebony pegs in it..... When I get around to applying the finish I'll post a picture.
I meant "the" pegs in place.
>My son was talking to me about his Ipod and I got distracted.
Re: Thanks, now I'll have to try it.
Great story, Eddie! :-))
Re: My little peg polishing jig
Thomas S Stockton
>Eddie
That's a cool little jig and makes it easier to do the pegs. I've made a set of chairs once that I forgot I had lefts and rights of a bottom stretcher and made holes for pegs on what I thought was the top of the stretcher. While dry fitting I noticed the problem so the chairs had pegs on the under side of the stretchers as well.
Tom
