THE WOODRAT IS BACK!
Circle Cutting Jig For the Bandsaw, ??
Jim Shaver Oakville, Ont.
>Hi All,
I had a link for a circle cutting jig for a bandsaw, of course I have lost my link. Now I need it...and I am trying to not get lost looking (IE sucked into the internet).
I am sure I can figure out how to make one but I would like to review it against a plan if I could to verify I got it right...any links would be appreciated for such a plan.
Thanks,
Jim
Re: Circle Cutting Jig For the Bandsaw, ??
Jesper, Denmark
Jesper, Denmark
>Is this what you had in mind?
It is upside down and on the tablesaw here, so you can see the bottom.
Jesper, Denmark
Jesper, Denmark
>Another view
Jesper, Denmark
Jesper, Denmark
>and one more.
There is a pin in the bottom of the blank and a row of holes perpendicular to the blade.
Your shop must have come out of hibernation, eh?
Killer service, Jesper!
Eddie Pacheco; San Jose, Ca.
>Twelve minutes, three pictures, and a complete answer.
No Kidding!
>Thanks Jesper,
This is simple and clean, Love it!!
Thank You very much....bet I can make this in 15-20 minutes eh!
Take care,
Jim
Jesper, Denmark
Be prepared, be prepared, dadada dadda...
Jesper, Denmark
>Just pure coincidence. I did this for a local Danish forum just a few days ago. The original was a bit more complete, but I do know that the "stuck chuck Canuck" is a pretty fast learner, so no need to cut it out in cardboard.
On-right, off-left; On-right, Off-left.................
Why Is A Keen Minded Human Being ????
>monkeying around looking for a missing Link?
Hi Jim,
Sorry, I couldn't resist. The answer is available in various woodworking circles.
George
Circle Cutting Jig For the Bandsaw, use tip!!! *LINK*
Lee Schierer - McKean, PA
>When you set up your jig, make sure the center of the pivot is aligned exactly with the front of the teeth on the blade. If the teeth are ahead or behind that center, they will walk and make the circle non-circular. I use a jig that was originally sold by Tuff Tooth, which I beleive is now owned by Kreg. It has an adjustable slide with a sharp pin for the center. I have included a photo and a link.
Lee
Circle Jig
Jesper, Denmark
Re: Why Is A Keen Minded Human Being ????
Jesper, Denmark
>Colonel,
Are we going around and around on this?
Re: Circle Cutting Jig For the Bandsaw, use tip!!!
>I was going to point out that the center line of the pin MUST be aligned with the front Edge of the teeth, but somebody beat me to it. And, you should use a fairly narrow blade with considerable set in the teeth. The Super Smooth cutting blade you use for resawing will not do a good ob of this. I made one set up for the 3/8 blades I was using at the time and it worked reasonably well. Switched to half inch blades and Its not worth a crap.
The slider is a nice touch if you pan to use it much. After a while, the holes over lap.
I use mine to cut bowl blanks. Now, I just put the blank on it and slide it through the saw, turn the blank about twenty degrees, hack off a corner, turn and hack. End up with blanks that are about ten sided.
>Thanks Buddy!
Take care,
Jim
Re: Why Is A Keen Minded Human Being ???? OT
Yonak
>Excellent question George, and one on which I have developed a recent theory. Perhaps we are wasting our time looking for that elusive missing link, erroneously believing that it happened over such a long period of time that there must be many samples which could be unearthed. ..But think of a bacterium or virus that mutates and jumps the barrier and which, say, becomes resistant to common medicines or develops a different method of transmission. You don't think of a link between these two different bacteria. It, likely, happens directly from one host to an offspring. Perhaps it happened that way in the mutation from ape to man as well, directly from the mother to the child, or in a very few generations. As such, it would not be surprising that such a short gestation period (or no period at all) would lead to the discovery of a linking sample.
