Question - Need a metal engineer
jeff
>I've tried to look up this information, but no luck.
About 3 years ago I built a Mobile base for my jointer.
I used 4"x4" pressure treated posts as the supports.
I want to build a new replacement base out of metal.
While the 4x4's supported the jointer with no trouble, they have finally warped from the weight.
I tried to find some metal tubing, U channel, or angle iron.
My supplier says he has no idea of the strength and suggested a 4" U channel should be strong enough.
Does anyone have an idea of the strength of this stuff?
Should I be looking for something else?
What is the strength of a 4x4 PT post in comparison?
My friend can weld this together, but doesn't have the foggiest idea how strong the channel is, he thinks it will work.
The jointer is a 1924 American and weighs close to a ton.
I know my 1000lb planer is easily carried on a 1"x3" tubular steel framework.
