How to fix floor squeak
Bill Tindall, E.TN
>Right where my feet hit the floor from bed in the AM the floor squeaks. The problem is the floor is carpeted and it is 2nd story floor with no access from underneath. The one time I tried screwing through carpet, the fibers wound about and strangled the screw.
I can find the joists. How do I pull the 3/4" plywood subfloor down to stop movement? I suspect the answer is a screw but then how do I deal with carpet and pad? I would think there was a professional solution but it escapes me.
Re: How to fix floor squeak
del schisler
>try a nail gun shoot nail at a angle 1 one way and the other the other way Maybe the top floor section mite get drawn down?? I know a screw would draw both togother But maybe a nail mite work? At least it wouldn't get tangled in the fiber's And the nail would be invisable Just a thought del
Re: Yes, but with spiral shank flooring nails
Dave Mount
Several suggestions
Lee Schierer - McKean, PA
>1. Don't be the first one out of bed then the squeek won't matter.
2. Don't be the last one into bed and the squeek won't matter.
3. Move the Bed!
4. Sleep on the other side of the bed!
5. Wear ear plugs so you won't hear the squeek, but then you might not hear the alarm either.
6. Pull up the carpet and observe the actual problem so you can fix it properly. Most likely you have two pieces of ply wood coming together and one of them is loose and rubs on the other when ever it is stepped on. My solution would be to put glue in the crack and screw down the loose piece with several screws into the joist.
Lee
Lan Brady
>Bill,
I have no experiece with this. The system that Brian has recommended, is the one Tom Silva used on "Ask This Old House".
If it works for Tom, I am a believer!
Good Luck, Lan
DaveRe: Yes, but with spiral shank flooring nails
George Koch
>Bill, as suggested by Dave. Spiral shanked floor nail into the joists and finish driving them home through both the carpet and pad with 3/16" drift pin or large nail set. George
Re: Devere: Yes, but with spiral shank flooring na
>As a Builder I used to deal with this occasionally in the house I built. I also get questions on it now as a home inspector.
The problem is that something is moving and it is rubbing against something else. Either the edges of two sheets of plywood are rubbing together or the plywood (OSB/particle board, whatever) is rubbing on the shank of a nail.
The best answer is to roll the carpet back and screw the floor down to the joists. Often a PITA in an occupied house, but a good plan next time you replace the carpet.
The second choice is to use screw or ring shank nails with small heads. I often used 2 1/2" 8d spiral shank siding nails. Find the joists, drive the nails through the carpet. I usually sort of comb through the pile of the carpet and try to find a void or bald spot where the backing shows. Just as the head of the nail comes to the carpet, I use a razor knife and insert it beside the shank of the nail and cut a single strand. Then pull the carpet up over the nail and insert a punch or nailset through the hole and finish driving the nail. Fluff the carpet. This is exactly what was described by others, but I thought I would share with you that I have done it many times and it worked.
thanks
Bill Tindall, E.TN
>I'll have at it as soon as I get the doors hung (another dangling project)
Squeeeeek-No More
>I use them.
They work.
[Every time]
mm
How about T&G wood flooring?
Brint in Richmond, VA
>I've got three or four places that squeak on the stair landing (outside our bedroom), but am worried about punching holes in the wood floor - ?
Negatory on Squeek-no-more
Rich Pearson in Mill Creek
>I used about 100 of them, Followed directions, including standing over area being screwed down. Didn't help a bit!
I must have a really crummy constructed floor ( or the edges of the subfloor are producing the squeek) as the floor is noisy as ever.
Once my hands heal up I'll move all the furniture out, pull up the carpet and take a skill saw to run a kerf everywhere the subfloor panels join.
THEN I'll nail the snot out of the panels with ring shank nails!!!!
Another solution
Al Goldstein
>Bill,
There is another source of floor squeaks that won't be fixed by the usual solutions.
When my son bought his house he and I removed all of the carpeting to get rid of the smoke odor. We also used this opportunity to drive tons (well almost) of three inch screws into the floor joists (just followed the nail heads) to eliminate most floor squeaks. However, in a main hallway we could not eliminate some bad squeaks. Luckily I located the source of the squeaks by remembering how houses are constructed. The floors are laid down and then prefabricated walls are nailed into place. Maybe the wall sill plate is moving with respect to the floor. I verified this by testing a closet floor on the other side of the hall wall. Sure enough I heard the same squeaks.
Drilling holes on the side of the wall and dropping long nails in the holes I was able to locate the wall sill plate in the basement ceiling. Driving three inch screws upward into the sill plate fixed the squeaks. Finally my son realized that his dad wasn't as dumb as he had thought in his teen age years.
This easy solution is not possible on the second story, but long screws could be "toe nailed" into the wall to fix the wall sill plate to the floor.
This may not be the cause of your floor squeaks, but it always should be kept in mind for the nasty squeaks that won't go away.
Good luck.
Al
Re: How about T&G wood flooring?
George Koch
>Brint, There's a good chance the landing wood floor got installed without a layer of building paper between the subfloor and finished floor. Short of face nailing it down you could try sweeping some talc powder into any opened t&g joints in the flooring. This sometimes works. George
