With apologies to Harry Nilsson...
Mike Hamilton
Mike Hamilton
Here�s why I did not go to work today *LINK*
Mike Hamilton
>Apologies to you also because I don�t know how to link multiple pics directly into the post, so I�ll break this into multiples. Each post links to a separate album in Picasa. Even if you don�t expand the pics, roll your mouse over the thumbnails as there is some additional info in each caption.
I drove across Indiana in the fog this morning to join Jennifer Shirley and 15 of her other friends for a tour of the Frank Miller Lumber company � what a treat!
FML is outside Union City Indiana. If you didn�t have directions, you�d not likely find it. You knew when you were close because nothing is quite like that mild acid smell of fresh cut oak.
We got protective gear and a bit of an orientation then headed off in two groups.
Starting the day
About the blades *LINK*
Mike Hamilton
>First stop for our group was the blade sharpening area. The head saw and the two resaws use 50 foot blades. The plant runs two shifts and the each saw goes through two blade changes per shift (need it or not).
As blades near the end of their useful lives, they are saved for a special event. Every once in a while, the log buyers come in and go through all the saved logs that were vetoed by the metal detector. The metal is dug out by hand and the logs are sawed with the �old� blades.
The blades
Not your average yard *LINK*
Mike Hamilton
>The log yard is about as bare as they ever let it get. Downturn in the economy coupled with a wet spring has meant a slowdown in log delivery. FML is constantly cutting about 2 to 3 months ahead of delivery, so the sales staff is getting antsy about the yard right now. FML sells mostly to custom cabinet/furniture shops in the Midwest, a few large commercial regular customers (largest is Stickley) and bids on large one-off jobs as well (like a quarter million feet of rift sawn white oak flooring for condos in NYC).
Log Yard
Slice *LINK*
Mike Hamilton
>We weren�t allowed to take close shots of the head saw, as FML doesn�t want to give up all their efficiencies. I later found I could have taken shots from a distance but it was too late. Perhaps Jen or Dick Gerard can jump in here with a shot of the head saw. The carriage and saw are used to trim, halve then quarter a log. Capacity is 54 inches. Logs under 16 inches are not bought. Logs at the high end of the range are not an efficient use of the head sawyer�s time and those beyond range are impossible, so a second shift Al Crandall type built this log splitter.
Log Splitter
And dice *LINK*
Mike Hamilton
>Once off the head saw, the quarters feed two resaws. The lines are manned by two guys:
one plays whack-a-mole with pneumatics that stop logs on the chain and flip them to present the most quartered face
the other uses lasers to line up the log for the straightest cut (this guy, like the head sawyer sits in a cushy chair behind glass)
The logs circle continually for cut after cut until gone.
Resaw process
What grade did you get? *LINK*
Mike Hamilton
>Next step is grading the wet lumber. One guy marks, several dead pile by grade (on an interesting roller setup) and the lift operator carries off the piles by grade. Our group did not get to see any stickering being done � but it is done by hand.
Grade and stack
All but the oink *LINK*
Mike Hamilton
>Bark from the debarker gets sold as mulch, sawdust is used to fire the boiler at the kiln, large bits are ground into chunks and sold to a paper mill (chunks are blown into a semi and in extreme cold freeze into a tight block � the mill unloads by tipping the entire trailer � imagine emptying a can of jellied beets from a soft can and check the pictures)
The sawing process is all 15 feet in the air and a river of shakers and vibrating slides moves the waste to its destination.
All but the oink
Taking the air *LINK*
Mike Hamilton
>Stickered lumber spends roughly 30 days in the air. There were acres of it to see.
Air drying
Powered by steam *LINK*
Mike Hamilton
>The kilns are provided with steam by using conditioned water (they go through over a skid of softening salt a week) and burning the sawdust. The sawdust feeds the boiler from the bottom via augers and as partially burned bits rise in the stack, air is injected midway to complete the burn. The watered fly ash from 3 days burning barely fills a 5 gallon bucket.
'bout that boiler
It�s a sauna in here *LINK*
Mike Hamilton
>FML has 15 kilns at this site and also has another drying site in southern Indiana. The kilns are either 60000 board foot capacity or 90000. Length of stay depends on many variables, thickness, season, weather, how much �free drying� they got out of the air drying cycle. Generally 4 quarter stuff spends at least 30 days in the kiln. The kiln is remotely monitored all the time, sample boards are monitored manually. The kiln reverses the direction of the air flow on a regular basis to keep one end of the load from drying faster than the other. Interesting thing about the sample boards � the sample boards are cut and then a dry weight is calculated and written on each board.
Reaching the target weight is how �dry� is judged. The there is a �conditioning cycle where some moisture is reintroduced.
In the kiln
Show me the money *LINK*
Mike Hamilton
>After drying, the lumber returns to the mill. It is run through the surfacer and graded again. It might be graded by width as well, or possibly trimmed to width, depending on the order being filled.
FML keeps 180 employees busy at this sight � 50 in the drying area the rest at the mill, the back office and the retail outlet. They have another 50 people at the Salem drying site. On average, they ship 1.2 million board feet a month of quarter and rift sawn oak lumber. We were told they occasionally have a 1.8 to 2 million foot month but those are special and leave folks pretty beat by the end.
There was a lot to absorb and I�m sure lots that I have forgotten � and maybe a few details I don�t have exactly right. But I came away with the sense that FML is efficiently run, rightfully proud of the products they sell, and is a responsible corporate citizen of both their industry and their community.
I am so very, very glad that FML was so hospitable, that Jen put this whole trip together and that �. I did not go to work today.
Regards,
Mike Hamilton
Plainfield, IN
After the kiln
Great pictures Mike!
Jennifer@Indy.USA
>Great pics and great write ups! Thanks :)
Glad you weren't at work today.
Jen
Excellent presentation, Mike
>Thanks for documenting a very illuminating visit. I'd like to create an article from your words and pictures. Stay tuned for that.
Cheers,
Re: With apologies to Harry Nilsson...
Jim Shaver Oakville, Ont.
>Really well Done Mike!
So how much wood followed you home??
Looks like it was a lovely day!
Take care,
Jim
mike hamilton
>Not much lumber followed me home, but this will not be my last trip there. And the afternoon rust hunt is a whole separate story....
Regards and a belated happy b'day,
Mike
