200+ woodworking book reviews
Wood Markings
Wood Markings
Wood Markings
David Ragan
>Hello,
While reading some of the older texts on woodworking, I've noticed that the artisan sometimes places a "v" on a jointed edge, then an "f" on the adjacent, jointed face. Is this what these symbols mean? That these surfaces have been trued? Are there any other symbols used at times?
Thanks.
Re: Wood Markings
Not sure
Lee Schierer - McKean, PA
>I'm not sure about the symbols you read about, but when I am laying out a panel for glue up to select the wood, when I have the arrangement that I want, I draw a large V with chalk across all the boards. This tells me their relative orientation and also which side is up. Chalk comes off with the final sanding. You can then do the final jointing and glue aplication without fear of getting the pieces mixed up. If, I'm doing two panels, I use a V on one and a W on the second.
Lee
Re: Wood Markings
Re: Not sure
Dan arrowsmith
>many moons ago when i was in school the woodworking teacher taught to use a g (good)on the 1F face and use this as the reference. The tail of the g had an inverted v on the second 2F face. esier to show that explain
Re: Wood Markings
Re: Wood Markings
Warren in Lancaster, PA
>When truing a board by hand, you first plane a face side, then a face edge. The face is marked with the f and the edge with a v. They point to each other, so that if you see one face and one edge, you can tell the orientation of the board (if you see no marks it is the far corner). All subsequent measuring and marking squaring etc, is done from these two surfaces, for more accuracy.
