How to change the size of a Kitchen cabinet
Larry
>Oh wise and mighty group..
Any suggestions on how to make a 18" tall kitchen wall cabinet into a 12" tall kitchen wall cabinet. My Counter top microwave had died and I would prefer to go over the range but the 18 cabinet is to low. I need it to be a 12" cabinet for a microwave to fit. I don't have any other cabinets in the kitchen to switch it with so I was trying to determine how I could cut it down and adjust the doors but still have it look good (Decent anyway)
Any and all thoughts are appreciated.
Larry
Re: How to change the size of a Kitchen cabinet
Need more info
>It's pretty short order to cut down a cabinet, but the doors are where the rubber meets the road. Are you prepared to make the doors over again?
Ellis Walentine, Host
Curly Smith
>If I understand your situation correctly, you may end up with a fairly useless cabinet - a small cabinet above the microwave that's above the range.
How about making it a spice rack? A book shelf? A curio shelf?
As Ellis says, the problem is the door. Unless you already have the bits to make the door then you'll have a very expensive door to make, or you'll have to buy one, or you'll have to turn the current space into a "feature". Haven't you always needed a place for that special bowl?
>I'm guessing your cabinets don't go to the ceiling. How about just raising it six inches and rearranging the trim detail around the top?
John Pappas
>Larry, I had to go from an 18 inch cabinet to a 15 inch cabinet when replacing a very old, and smaller, microwave. I had the time, so my approach was this. Build a new cabinet and try to match the doors and the color. Plan B, if that failed, was to make some doors that would blend with the microwave and paint the cabinet black. With luck and some degree of skill, I matched the cabinet almost perfectly. I might add that I think building a new unit is less tricky than trying to cut one down. Also, I could not throw the old cabinet away, so I added a base with legs and a top and it is now a cabinet in the shop.
Pete Stahl
>My brother did this or should I say I did it for him. Looked ok when it was done. Put some trim around the top edge but it wasn't crown molding. Had another brother who was lucky enough to find a manufactures stick on the cabinets and was able to get the smaller cabinet he needed. It wasn't that new of a house either, 8 - 10 years old.
John_in_Az
>I had the same dilemma that you have. My decision was easy for me because I needed to add some cabinet space as well as a nice spot for the microwave. So a new cabinet it was. I think all-in-all it was easier than trying to change the size of the original, and I ended up with a larger cabinet that custom fit the oven. Please disregard the ugly range that is going to the landfill, lol. John
Rich in Mn
>I did the same thing a few years ago, but only reduced the cabinet 3 inches. My doors were one piece so cutting them shorter was not a problem.
I took the cabinet completely apart. Carefully!! including the face frame. then cut down the pieces to the proper size and re-assembled the cabinet. It worked great.
If your doors are not one piece or you can't get the cabinet apart it will be easier to build something new.
In my case
John_in_Az
>The cabinet wasn't worth trying to salvage. Can you picture it being made from 1/8" doorskin ply with 1X2 pine in the corners, and ugly woodgrain pattern vinyl heat sealed to cheap mdf for the face frame. I have made new cabinets throughout but doing it myself haven't spent a lot of money since the whole house is worth less than my woodworking tools. John
Larry
>Rich,
How did you get the cabinet apart. Heat gun??
Thanks
Re: Need more info
Larry
>HI Ellis,
I guess I was looking for a way to cut the cabinet and the doors. I'm not to confident in my ability to match stains if I build a new one.
Thanks,
Larry
Here is how to do it....down and dirty
Bill Hammond, Oregon Coast
>My first thought when I read the subject was, chainsaw.
First remove the cabinet from the wall and remove the doors. You are going to cut the top off of the cabinet. Mark a line around the cabinet at 12" from the bottom. If you have a table saw with a fine-plywood blade use that and set the fence at 12" and run the cabinet through the saw 4 times to cut all the faces. Or, use a saber saw with a down cutting blade, tape at the cut, mark and cut the thing down. Now cut the frame down the thickness of the top piece that is left on the cutoff. Set the table saw for the thickness and make the cut, or use the saber saw again. Most likely the frame is held with pocket screws. unscrew and break the top piece off of the cutoff part keeping the top attached. There will be a board across the back for reenforcement and mounting. If you can keep it with the top good, otherwise move it to the proper place on the new top of the back. Drill down from the top for screw holds to attach the top face frame piece(won't get the pocket jig in to use pocket screws. Now glue and screw the top piece of the face frame and the top on to the rest of it.
The doors..
Cut the top rail of the door off with your table saw. Make the cut so you get the whole rail and part of the styles where they attach. Now take the panel out, most likely it will fall out. Now cut the top off of the styles at a point where putting the cut off rail back will give you a door of the right height. Figure out how tall the panal has to be and cut it to size. I am assuming a flat panal and not a raised pamnal. Glue the panel back in with the rail on top and drill and screw the rail back on to the ends of the styles.
If you have a raised panel door cut the top off with the cut just below the bevel. Cut the door down to size and glue it back to together with screws down from the top into the styles to hold it.
Go to a craft shop or a good paint place and get some colored putty sticks and fix all the chips and mistakes.
Put the cabinet back. If the fan vents through the cabinet make the adjustments to it while down. Remember you need an outlet in the cabinet to plug the microwave into. It's best to get the wire there while the wall is free and the holes will be covered up with the cabinet.
Good luck.
Bill, been there done that.
Oh yeah, be sure to fill the cabinet with nitrogen before making the cut.
two suggestions.
Roy Anderson
>Two suggestions:
1. See if you can find the manufacturer and try to order a new cabinet that fits your size.
2. Get a nice piece of plywood and just have a solid panel over the microwave. You can decorate the plywood panel in any number of ways to match your existing cabinets.
Rich in Mn
>The cabinet was glued and stapled together. I pull the staples that I could and worked carefully at breaking apart the glue joints. A rubber mallet helped. I was fortunate that nothing broke. The Face Frame too more force to break the glue joint but it came apart.
If you have a clamp that can be used as a spreader that would be helpful also.
Good Luck.
