cutting tung and groove oak flooring
Rodney
>I am building a mountain cabin and want to finish rough cut lumber as wood flooring and paneling. I have red and white oak for the floor and yellow poplar and pine for paneling and overhead. I would like to do all the cutting on one pass, but realize costs may require more than one pass. What is the best and most cost effective power tool to cut the lumber into tung and groove boards?
Re: cutting tung and groove oak flooring
>If you want them to fit, a dedicated moulding machine, which is a big ticket item. IMO, forget the tongue & groove, and just go with butt joints.
Clint
John Veerkamp, Western Mo.
>Easier to make and almost as nice are half lap joints. Two passes on a Table saw with a dado blade and you're done. lots of old cabins used this type of flooring.
John
There are probably reasons....
>...to try to mill rough lumber to t&g flooring, but I can't think of any good ones. I'm assuming that you mean to keep the rough mill marks on the boards. If not, color me mistaken.
Molding mills, with their multiple-head machines, can transform your wood into slick flooring in a single pass, but is that what you want?
Moses Yoder
Moses Yoder
>Is the wood kiln dried or green? What is the moisture content? As mentioned, the only good way to cut it is with a molder. You can buy good used molders for around $50,000. I am not sure what the accessories cost to make blades for it and sharpen the blades, but there are shops around that specialize in those items. If you go with just butting the boards together you will have to deal with larger offsets in the boards as they move during the seasons, warping and cupping. The large gaps between the boards would also let more air move through. A good alternative would be to buy a small shaper like the Powermatic 3 horse and a shaper head set to make the tongue and groove. A power feeder would be a good add on. You would need to set up the shaper and make the groove, then set up differently for making the tongue, so it would be a two pass deal. If boards need to be butted end to end for long runs of flooring the width would need to be matched. I plan on doing this myself for our kitchen and dining floor. I would make sure the wood is smooth enough that you don't get slivers from rubbing your hands across it.
James Clair
>I would get the lumber cleaned up and surfaces. A well set planeer should do this just fine. Strait line to same width. Then use a shaper with a door rail cutter haeds. Good shapers are only $1500, a lot cheaper and more useful than a moulder. A good planer should be about the same.
>I would have thought the answer would be to take the lumber somewhere they have the machines and have them mill it for you. Not sure exactly who you are looking for, but it would be easier and probably better than trying to do it yourself.
