What Joint Type and Glue?
Garrett in Victoria
>Making a simple square table base out of Jatoba to support a 40" d circular glass top. 4 legs 1 3/4" square joined by a 2x6 '+' frame mortised into the legs 6" below the top.
The question is what joint to use for the 90� crossover of the frame.
I haven't used Jatoba before, so just checking whether there's any special requirements for glue.
TIA, Garrett
Re: What Joint Type and Glue?
Half lap & Titebont
Left out an important detail...
Garrett in Victoria
>The crossed boards are joined upright rather than flat, and the joint needs to be strong, because it and it alone holds the table together. I fear that a vertical half-lap won't be enough to do the job.
I'm thinking one long board with a shallow (1/8") mortise (registration only) plus 3 through dowels into 2 short boards, but is ther3 a better way?
Cheers Garrett
Moses Yoder
Re: half lap
Moses Yoder
>A good half lap joint is the strongest way to do this in my opinion. You need to make sure the board fits tight into the joint to prevent racking movement, or perhaps add a ring or center apron to the design. I would glue it and put a screw through the bottom apron into the top apron.
Half lap it shall be. Thanks to both of you.
Garrett in Victoria
