Re: sagging and bulging *LINK*
Dave Mount, snow's almost gone
>You seem to be talking about two different issues. The fixed middle shelf helps hold the sides of the bookcase from bulging out. But you're also talking about shelves sagging.
For the sagging question, there's a program on the net called "The Sagulator" which is a calculator that figures sag in shelving based on the materials and construction. I can't vouch for it's accuracy, but I've put a link to it below. 3/4" ply with 1.5" edging does not sound up to a 4' run of books in my mental calculator, but you should run the calcs.
With regard to keeping the shelving sides in, that's primarily a funciton of using hardware for the adjustable shelves that doesn't create a side load. From where I'm sitting, I can see a 4' wide by 7' tall case that we bought before I started woodworking. It has a vertical divider, so the shelves are only 2'. However, there is no central fixed shelf, and all the 3/4" ply shelves are on 1/4" brass paddle pins. There's a 1.5" face frame. We've had it for over 20 years, it's loaded to the gills with books, and the sides have not spread.
Best,
Dave
The Sagulator
