how to control appetite of duct collector
Bill Tindall, E.TN
>If I have some quick sanding to do I lay the 5" drop to the jointer up on the bench and turn on the dust collection. Apparently the small amount of dust I generate is insufficient to satisfy my DC appetite. Yesterday it ate two sanding blocks careless laid in its reach as well as numerous scraps of sandpaper and a marking knife. In the past it has eaten a bench brush and even small parts.
Can someone think of a coarse screen that I could handily snap over its mouth for these occasions- something that would filter out bench brushes yet not impede air flow? And it needs to be quick to add or remove when the drop returns to the jointer.
I was eying the flour sifter but I got a look that suggested this was not an option. Anyway, its screen was a bit too fine. But something on this order would do.
Re: how to control appetite of duct collector
Ummm...
Forrest Addy
>Cut the bottom out of a 3# coffee can to maake a sleeve and solder a 1/4" hardware cloth screen over the end. Paint it to look like shark jaws with a muzzle straped on them.
solder?
Bill Tindall, E.TN
>Can I solder hardware cloth to a steel can? That would be just what I want if the solder works. I've got the can and hardware cloth.
Re: solder or
>Sand the can metal bright and do not touch the brite part with your hands. Do the same with the cloth at the points of contact. Use regular flux on both pieces. 4 or 6 soldered spots will hold quite well.
BTW, you can also use a few pop rivits with fender washers to do this.
Re: Metal Collection Grate
Chuck in ND
>I'll suggest this even though I'm not overly happy with Penn State Industries right now. http://www.pennstateind.com/store/dgr.html
>Bill, either of the above suggestion will work, but have you thought about a downdraft table? Somebody makes a "box" you can hook the dust hose to, or you could make one. It has a grate for a top.
I have been thinking about it and am scheming on a cart with a furnace blower in it and a grill on the top. The plan is to use it for both a sanding station and an ambient air cleaner.
Re: Ummm...
Bill Hammond, Oregon Coast
>Seems like a lot of work, why not just punch a lot of holes in the bottom of that coffee can? Sort of like the tin punched pie plate door inserts. Just use a large nail and a block of wood to support the inside.
Or, some plastic mesh that is used to cover plants and a large rubber band to hold it in place.
Bill
Chuck in ND
>Delta makes a AP075 table top downdraft table that hooks up to a 4" DC hose. I have one, but haven't used it yet.
Bingo!
Bill Tindall, E.TN
>I have some plastic trellis. that, the ever popular Duct tape and a coffee can and I'm there. However, I still intend to test this can soldering. It may be handy down the road.
Another Approach
Chicago Bob
>Bill,
Try partially opening another gate in the DC system to bleed in additional air to "better balance" your system. Sounds like too much suction for a single point of use.
Regards
Bob
>That's what I was trying to think of, but I was thinking against the wind.
Dave
Where do you guys get metal cans?
Dave
>All of the coffee that I have bought in the last 3 -4 years have come in plastic cans. Maybe its a west coast thing.
Dave
