pointy plug question
Bill Tindall, E.TN
>I want to plug some 1/4" screw holes with those nifty plugs that have the 4 flat faces that come to a point sticking out (tetragonal prism for those geometrically inclined). Boggs chairs and some other stuff has them.
So, does one make pointy plugs and drive them in, miraculously stopping them at the exact depth that they look good. Or, does one drive a plug in and somehow by means that have not become obvious to me, point them afterward?
If I can ever get it figured out how to clamp the *#&!! thing they go in I will post a picture.
Re: pointy plug question
Phil Joines Krum, Tx
>I've always driven them in, trimed to length and cut the facets with a chisel.
>There was an article in FWW within about the last year on making plugs. (Whodathunkit and it was along article too.) As I recall They drove them in and then pointed them with a chisel. A very sharp chisel and what looked to me to be more skill than I have. I think they were placing the chisel beside the plug with the bevel down and the handle up and pressing the chisel into the plug and lowering the handle at the same time.
I also seem to recall making the plugs with a round shaft and a square top. Seems to me they set up to make them in rows and beveled the tops and then drilled them out from the back with a plug cutter. Not even sure it was the same article. Dismissed both methods. One required skills I don't have and one way too complicated. Wonder if you can buy them?
I need a picture
Bill Tindall, E.TN
>I am not seeing how to orient the chisel to cut a facet with the plug in a flat surface. Seems like one would have to pare downhill against the grain. Maybe that works with a light cut? I don't see how to pare uphill with the grain without the surface the plug is in getting in the way of the chisel handle.
FFW #185
mdclor
