Drill Press Mobility
Tom Rex
>I'm looking for plans for a good mobile base for a floor model drill press. Or is there one that can be purchased?
Re: Drill Press Mobility
A piece of plywood 8" OS of the base & 4 casters
Forrest Addy
Re: Drill Press Mobility *LINK*
Dave's Not Here
>What I did for my floor drill press was to make a base using one of the old Harbor Freight Mobile Bases and some 2x2's. I cut up and glued the 2x2's to make a 24 x 24 platform that fit into the HF base unit and lag screwed the two together. Finally, I lag screwed the drill press base to the 24 x 24 platform. The reason I chose the wide and deep platform size was to help make the whole thing more stable when sitting still and when moveing the DP around.
You can't get the HF mobile base any longer but Woodcraft has one available that is similar in design.
Woodcraft Mobile Base
2" square tube steel
>I used 2" square steel tube (I think 3/16" wall thickness) and cut out a couple of slots on one side. I mounted some steel wheels inside the tube offcenter enough so that part of the steel wheel protrudes from the under surface of the tube. Then bolted the tube to the side of the base. Perhaps I should get a diagram or soemthing, cause I can't even follow that I just wrote.
Happy Woodworking!
Jay St. Peter - SoMD
>I used a similar Delta mobile base that uses 2x2 hardwood for the structure. I built a base extension on the DP using 2x4s to make a frame 1.5" thick, with a piece of ply on top. Then I bolted that to the mobile base and bolted the DP to that.
That was my solution, too. Works very well.
Garrett in Victoria
Al Stokka - Cambridge, Iowa
>Tom,
General International had one (in 2004). It works nicely with my heavy Delta drill press. I can get the model number if you'd like it.
Al
Personally, I'm not a fan of making a DP mobile...
Brian in Sandusky, OH
>Only my opinion, but I built a mobile base for my drill press a while back, and it works fine, but it was a little tippy, and you had to be careful.
I have a youngster that likes to be in the shop with Daddy, and once he got to the age where he's out there with me, I got the drill press off the base.
It never tipped on me when it was on the base, but a tiny pebble could cause disaster with my little guy running around.
Re: Personally, I'm not a fan of making a DP mobil
Chuck in ND
>Brian is correct about the drill press being tipsy on a moblie base, especially mobile bases that lift on one end. I had one under my old drill press and I really needed to be careful when moveing it, the drill press I had was backend heavy because of the motor. IF I was to do it again I would use a HTC type mobile base that the wheels locked instead of a mobile base that lifts on one end. Even then I would proceed with extreme caution.
john c. (virginia)
>For my Delta DP, I glued and screwed 2 pieces of 3/4" plywood, 24 x 26 1/2. I attached 4 casters to the outer edges. The DP is bolted to the base. I routed the edges and stained/urethaned. Doesn't look half bad.
Not fancy, not high tech, but a functional solution that has held well 5+ years and counting. No flex. No problems.
Good luck.
Brint in Richmond, VA
>Love the base, Jay -- is the cabinet removable? I've thought of doing something similar with the cabinets constructed as part of the base (thinking "why would I ever need to lower the table more than, say, 24" below the drill bit?"), but wondered if I should err on the side of caution and keep them removable - ??
Tks --
Jay St. Peter - Southern, MD
>Yes, the drawer cabinet just sits on a platform created over the DP base. I can pick it up and move it. When full, it's heavy enough to stay in place when being rolled around. I have had it in place for a few years and never removed it, but I can if I need to.
Jay
