Need some help adjusting a Unisaw
Phil Joines Krum, Tx
>Been doing maintance on the TS's at work. On one on the Uni's the height adjusting rack and pinion is about ready to slip. There's less than 1/8" contact between the teeth. I can't find an adjustment to raise the pinion. As far as I can see both ends of the shaft are bushed into the castings with no adjustment. The saw it probably 15 years old. The model number is 93 G 95225 which doesn't look like a Delta number to me.
Anyone know how to adjust this thing?
I looked on the Delta/DeWalt site for the manual but if it's there I couldn't find it.
Re: Need some help adjusting a Unisaw
BTW
>None of the tops on 4 saws are square to the blade. The miter slots are out by about 1/8". They have been using sleds to crosscut.
Re: Manuals *LINK*
>Right tilt
http://www.dewaltservicenet.com/Documents/English/Instruction%20Manual/Delta/En%20422-04-651-0064.pdf
Left Tilt
Re: Manuals
>I found that too. Also found some parts breakdowns on the Old Woodworking Machines site. From the looks of it there isn't a way to adjust the spacing but that doesn't make sense to me.
