Air compressor lines material?
Pat Matranga
>Hello everyone,
I just found this site. I am replacing the PVC lines I have used for my air compressor. I have learned that they are dangerous as they can explode. What is the best material to use? Copper? I've heard about something called "pex"??
Thank you.
Re: Air compressor lines material?
Eddie Pacheco; San Jose, Ca.
>First of all you have found pretty much the best woodworking site on the internet. Welcome!
It not that PVC pipe, used in compressed air systems, explodes. The thing that most often happens is that a protruding line connection is bumped or hit with something, it breaks, and then there are plastic shrapnel sent all over the shop. I've seen a lot of old PVC installations that have worked with no problem. Also if the person has used the thiner walled sch. 20 PVC there is potential for an easier break if the line is hit or bumped.
For me copper worked best as it is easier to cut to length and solder than galvanized pipe, which needs threading. There are nifty handheld electric threading machines that you can rent that make this job easier, but copper lines are easier to customize to a shop space.
I don't have any experience with PEX. I have used polypropelene tubing with swage type end fasteners on manufacturing equpment and they worked well at 125psi and above.
I hope this site helps you in your future projects.
Jerry
>Pex is a semiflexible plastic water pipe. If you will do some searching on this forum you will find a lot of posts on this subject but the consensus seems to be copper or iron pipe. Or for a simple run, a regular air hose would work.
Jerry
Check out:
>From the Kaeser website
SmartPipe�
SmartPipe� modular aluminum piping is a flexible, affordable and efficient compressed air delivery system. Made from calibrated aluminum, SmartPipe� can be fully integrated into existing piping systems. It can be easily installed without threading, sweating or welding, and does not require any special tools.
http://us.kaeser.com/Products_and_Solutions/default.asp
