Hide Glue Part II-hammer veneering in dry climates
GolfSteve in Calgary
>Part II - hammer veneering in dry climates
For a while now I've been hammer veneering with hot hide glue. This, in my opinion, is where hot hide glue really shines. For small to medium sided panels I find hammer veneering is much easier than fighting with PVA glue, curling veneer, cauls, battens, squeeze out or bleed-through interfering with your finish, etc�..
However, last night I spoke briefly with one of our local recognized "experts" in the field. He is English trained and emigrated to Canada many moons ago. He gave a presentation on veneering to our club last night, but he noticeably left out any discussion of hammer veneering. I asked him about this after the meeting and said that in our very dry Calgary climate hammer veneering was problematic due to cracks appearing in the veneer. The problem is the large amount of moisture that enters the veneer from the hide glue. The subsequent drying causing cracking of the veneer. He does not recommend hammer veneering for that reason. We did not have time to chat, so I was not able to ask more questions about why the moisture in PVA doesn't cause similar problems.
This might be the cause of some cracking that I experienced last year�.I had put it down to the use of crotch veneer, but perhaps it was caused by the hot hide glue in a dry climate? The cracks appeared about a month after the piece was veneered. This has happened to me twice, but both times it was with the crotch veneer. I've hammer veneered straight grained cherry several times with no problems. I've also hammer veneered figured sawn veeneer (1/8" thick) with no problems yet but it was only veneered a week ago.
Here's a picture of the cracked crotch veneer and a piece of the piece:
I really hope that I can continue hammer veneering, but if it is a problem in dry climates I might have to switch to a different method. Has anyone else heard of or experienced this problem with hammer veneering in dry climates?
Thanks in advance,
Steven
