The case against hot hide glue - Part I
GolfSteve in Calgary
As much as I would like to like hot hide glue I want to poke at Stephen's obsession with boiled cow hides a bit :-)
1) It's a royal pain to use. No way to skirt around this by saying it just takes a baby bottle warmer sitting on the bench, etc. It is a royal pain compared to liquid hide glue or titebond. Epoxy is the only thing that is more of a pain in the butt than hot hide glue just because epoxy is so hard to clean up.
2) The wife really doesn't like me using the baby bottle warmer to heat boiled cow hides in my dirty shop. Somehow she knows I've used the bottle warmer even when I try to hide it.
3) The glue sets up way too quickly - it requires you to completely change how glue ups are done - eg. when assembling a mitred frame you almost have to assemble and glue one corner at a time. If you try and assembly all four pieces (and the panel) you will have a disaster. Even with a hot shop and pre-warmed pieces, you only have 30 to 60 seconds to get the whole thing assembled, squared up and clamped. That's way tooo short a time.
4) You have to pay a fortune to heat your shop to unbearably warm conditions in order to delay the glue set-up for several seconds.
5) The first batch I got smelled really bad (must have been bad). Newer batches smell like roast beef, making me hungry when I should be concentrating on my glue-up.
Don't get me wrong, I'm really trying to like hot hide glue, but it just ain't working for me. I like how it cleans up nicely and doesn't interfere with finishes. I like how it is repairable and can be temporarily released by heat and hot water. I hate how terribly fast it sets up - which makes it almost impossible to use for anything that needs a bit of adjustment during glue-up (eg. squaring up a frame).
Hot hide glue has almost disasterized more of my glue-ups than any other factor, except for the one that my first year computer science professor used to spout every time someone asked a question�"because you're screwing up!"
On the plus side for hide glue, I do like Patrick Edward's Old Brown Liquid Hide Glue. It is just as easy to use as PVA, although it sets up quite a bit faster than PVA. On the negative side it is a pain having to mail-order your glue across an international border, so next time I'll give Franklin's a try just because I can buy it locally.
See Part II for more about hammer veneering in dry climates. I wanted to keep that as a separate discussion because it is the more serious part of my questions about hot hide glue.
Best wishes,
Steven (who also does not like PVA glue, doesn't like epoxy, and hates cyanoacrylate (which also does not work well in dry climates))
