Re: Nice design, Robin
Robin Corell in Atascadero, CA
>Thanks for the kind words. I have posted a couple of pics of making the stretches up above. I think what made them difficult was two things. First is that with my background as patternmaker I use a few different techniques than most furniture makers and for me curves are not particularly hoard or time consuming. So the rest of the cabinet, while some parts were time intensive none of it was particularly difficult. The second thing that made the stretches difficult was that they caught me by surprise. I don't work from drawings and in this case I am not sure if the complexity of the joint would have shown up. By the time I got to the stretches the rest of the cabinet and all the drawers were done and I thought I would knock out the stretchers in a few hours.OOPS, miss calculation on that. The funny part is I had complete autonomous creative control and could have changed the design at the last minute without client approval but this is how I thought it needed to be. I guess that is why the client gave me that creative freedom.
I attached a pic of shaping the pieces for the side panels. In the pic I am making the parts for the panels that will be carved and for those I used a piece of quarter sawn wood which gave me some plane sawn panels with a fair bit of wild grain. This will compliment the carved pattern. On the commissioned chest I used a piece of plain sawn wood to cut the parts out of which gave me a quarter sawn panel. This was important to the design as I did not want any wild grain run out to show in the panels. I then made several fences for my router table to cut the rabbits on the edges. I needed a total of nine fences for my router table but again curves are pretty easy for me and I was able to make all the fences and cut the rabbits in under a day.
If it isn't clear from the pic I made a template to trace the part on the board and then cut close to the line and finished shaping on my spindle sander. By not cutting the entire part out I have more control while shaping on the spindle sander. I then finished cutting it out and shaped the outside of the curve on my disc sander. A total of six pieces were needed for each panel. The glue up was actually very simple. I just did a basic rub joint with hide glue and came back the next day to tight joints.
I think the rustic look you are seeing may be a moir� pattern in the digital pic. the drawer fronts have a 1/16 gap between each other as well as on the edges and I think this is distorted in the digitalization of the pic to make it look like they are tilted in or out. I went to great pains to get them all even and flush and am re thinking that clean contemporary look vs. cock beading.
The drawers are constructed with a sliding dovetail on the fronts and a rabbit and dado on the rear. Because of the curved sides I needed to attach a strip of wood to transition from the curve to the straight drawer sides. These blocks also house the strips of wood used for the drawer guides. I have sent pieces of paper to the client so he can layout his coins and once I get tem back I will make the interior deciders. They will be basic egg crate construction half the depth of the drawer. I line the drawer bottom and sides with PSA felt but not the dividers.
Robin
