Table top attachment questions of ye:
Pete in Holland, MI
>Guys -
Building some Mission-style coffee/end tables with a glued-up top. Want to attach the tops to the leg frame work with some little wood blocks inserted to grooves machined into the leg skirts, kinda like I've seen Norm do on occasion. Couple questions though:
1) In relation to the finished table, should the grain in these cleats run vertically or horizontally (end grain faces the skirt groove)?
2) How thick of "toe" should I use to insert into the mating groove, which will be sized appropriately?
3) In order for the top to float thru the seasons, I know it can't be glued to the table skirt. Does the varnish pose a threat to this floating, or are there tricks out there to prevent the varnish from weeping between the top and skirt, adhereing the two pieces together?
Thanx !
