>I have some walnut and cherry lumber stored in an open shed in southside VA. The shed is open and exposed to the wind, but it has a roof and little or no rain gets on the wood. The lumber is piled and on stickers. My question is: is the lumber deteriorating? Is it subject to insect attack? Are there things I should be doing to protect it? I prefer not to spray it with chemicals for fear the chemicals would affect me later when I use the lumber. Any suggestions would be appreciated.
From my reading, the wood is subject to attack by certain types of power post beetles. Others may already be in the wood and may remain there for a year or more.
I have seen a treatment with borax recommended which is safe chemical. The link below from the WoodWeb has some information.
>My question is: is the lumber deteriorating? NO but if any rain can get to it keep it on sticks.
Is it subject to insect attack? YES Are there things I should be doing to protect it? Spray it .
Commercial lumber used to be dipped in a solution of tetrachloro phenol, sodium salt. Nothing you will spray will come close the this nasty stuff. I have used Lindane and have a gallon on hand for these occasions, but now you can't buy it. It was used to treat head lice among other things. It protects lumber for years. As an alternative I would spray with what ever is used for termites. The problem with bugs is that when they hit by the time you know it the damage is one.
>I've used a borax solution made up with a little bleach on white oak - I don't know how that would affect your cherry and walnut though. It does seem to keep the bugs and mold off of the white oak.
>Bill - your repsonse raises a question I have on the subject of storage. I recently came into a lot of old (20-50 years old?) wood. The previous owner had stored it on stickers. I'm in the process of sorting the wood and stacking it indoors on heavy (industrial) cantilever racking and pallet racking. My question is whether I should use stickers? Thanks
>>...My question is whether I should use stickers?
If you are storing it in an environment similar to where it was, you can stack it tight without stickers. However, if you are changing the environment, say if it has been stored in an unheated and unairconditioned barn or shed and you want to store it in an conditioned indoor area to acclimate before use, you need to sticker it.
In most parts of the country the equilibrium moisture content of wood that is air-dried in "outside" air is higher than you may want for building furniture, regardless of how long the wood has been stored.
>Keep the lumber on sticks when storing outside or when it needs to dry some more. Otherwise sticks are unnecessary once the lumber is air dried enough so it won't mold.
The "needs to dry some more" is obvious, the other maybe no so. When I have tried to store lumber outside dead packed it has become a condominium for all manner of bug life and mice. Mice pee a lot in the vicinity of their nests. On the other hand I have had lumber outside on sticks for 15 years with no ill effects so long as it stays covered and dry.
>If I am reading this correctly, I can leave the lumber in the shed, well back out of the rain, high and dry, indefinately, and there is little or no reason to spray it with a borate or whatever, now that it is nice and dry. Did I get it right?
If the sap wood of the walnut has been invaded by some sort of borers, will they fade away now that the wood is dry?
>Barry, there are some powderpost beetles (anobiid)) that go for green soft or hardwood only (20% MC and higher) but there are others (the dreaded lyctid) that like dry hardwood just fine.
If the wood has been stored for a while and is already below 20% MC, inspect it periodically for little piles of fine sawdust and holes which will indicate an active infestation. If you have lyctid ppbs in the wood, spraying the surface will not kill them - they must be killed with heat. Spraying may help prevent new beetles from entering the wood.
If the sapwood has tiny holes from anobiid beetles or large holes from other borers, they will be gone now the wood is now dry.
This information comes primarily from Dr Gene Wengert from the WoodWeb.
BTW, Dr Wengert indicates that applying Lindane to wood is illegal. It lasts forever and future sanding dust is very dangerous to anyone who breathes it. I realize you were not planning to use lindane, but I think someone else mentioned it. http://www.woodweb.com/knowledge_base/Treating_AirDried.html
This is interesting. I have some Boracare. It is a borate solution in Glycol. The company that makes it claims the glycol is a vehicle and will carry the borate to the center of a 12" square beam. They sell it to treat log houses and the structure of other houses. Commonly used to treat floor joists for Pbs and others. These joists would or shouldn e well below 20%mc.
I was reluctant to use it, because I did not want the glycol in the lumber. There is another version, Timbor that is a powder, that you mix in water, but it would not penetrate into the wood as well.
>Timbor is the one I've seen recommended the most.
But I'm not trying to be a panic monger. Remember, most people treat the wood with nothing and usually don't have a problem. It depends on your luck, how valuable the wood is to you, the length of time you plan on storing, and whether the dreaded type of ppb is close at hand. (Wengert indicated you can bring insects to your wood supply with a small infested piece of wood or even shavings.)
Once a guy gave me some walnut turning squares he had for years, 2x2x24. I actually watched a ppb exit from the end of one stored on a shelf near my lathe. I'd heard a faint 'scritch, scritch' which caught my attention and while looking for the source, I saw the little thing eat it's way to the surface.
Carb loading Anobiids and water to wash it down *LINK*
Lee Grindinger
>Anobiids, also known as furniture beetles and deathwatch beetles, are your main concern. These PPBs, the only true powder post beetle, have a yeast that allows them to convert the starch in drier wood to glucose. Anobiids can convert cellulose to glucose unlike the other borers which can only convert the contents of the cells, the starch, they are eating. Anobiids can survive in 12% lumber but cannot thrive without more moisture. In less than ideal conditions, below 12% and above 20% they extend their larval cycle by as much as a year or more. Optimum MC is 15% and they flat out die below 10% MC.
Anobiids will not bother your heartwood because the starch content in the sapwood is much higher than in the heartwood.
So, here's your key. Go to your weather site and get the monthly averages of temperature and relative humidity for your locale. Use this table, www.furniturecarver.com/EMC.html to determine the EMC of your lumber. If it's almost always below 12% or 10% on a yearly cycle don't sweat it, if the boards are exposed to EMCs higher than 12% for more than a month or two consider a treatment like Boracare or Timbor but only if the sapwood is important to you, these insects will not bother the heartwood unless it's much wetter than yours.
>By the time you see piles of sawdust your are screwed. They have already eaten a bunch of the interior. In my experience spraying will kill what is inside because the vapor of the spray will get in there. It may depend on what your use.
BTW, Dr Wengert indicates that applying Lindane to wood is illegal.... I am sure it is in commercial application. It lasts forever ......that is the idea
and future sanding dust is very dangerous to anyone who breathes it........... Well it leaves in the planer shavings so this is not an issue. Anyway, not many people died when it was used on children heads to treat lice, or other places for other insects, or flea soap for pets. If you are very old you have had lots of it on you if you had lice or pets. I think someone else mentioned it.............. Me, I love the stuff
>I have had these buggers eat ash, oak and walnut at well under 12%MC. And I have had them enter heartwood in these species, but not nearly as much as sap wood. The sap will be totally destroyed with occasional tracks into the heart. After loosing hundreds of dollars of lumber to these guys chemical warfare became a most acceptable plan, and it works.
Twenty years ago when much of the commercial lumber in these parts was dipped in tetrachlorophenol to control stain bugs weren't an issue. Now days, I don't see much lumber dipped and I don't know what is used or if it will kill bugs as well as stain.
>Having no knowledge of the conditions of your lumber or when the infestations occurred I can't possibly speak to your problems, Bill.
It's not hard to find the science on this issue, there's been lot of research done on this matter since it impacts the lumber industry to the extent it does.
