Staining Teak?
Staining Teak?
Staining Teak?
Garrett in Victoria
>Will Burmese teak take and hold an oil stain?
Cheers, Garrett
Re: Staining Teak?
That's a crime Garrett...! ;-)
HC Sakman
>Well, you won't get prosecuted for it but nevertheless...
If you want to match it to an older wood patina (in your boat, I assume) use linseed oil first, then whatever you'll finish it with. It'll catch up sooner than you think, especially if it's exposed to sunlight.
Chico...
Re: Staining Teak?
Re: Staining Teak?
>Try the Varathane oil based dye stain. It imparts beautiful color depth without clogging things up.
Clint
Re: Staining Teak?
Re: That's a crime Garrett...! ;-) -- Even worse
Garrett in Victoria
>it was made in my father's factory more than 40 years ago.
However, the old (purchased) chairs simply gave out. SWMBO had very specific criteria including swivel and tilt, and nothing was available in teak. What she ultimately had to choose from are quite dark.
The good news is that the table, though not large, is massive e.g. the solid top and base are each more than 3 inches thick, and the post almost 8 inches square. It will last many generations and won't be a problem to take it back to natural.
Thanks to both of you for the useful advice.
Cheers, Garrett
Re: Staining Teak?
sorry, that's not quite correct
Michael Dresdner
>I agree with your choice of stain, Clint, but your description of it is incorrect. Varathane does not offer an oil based dye stain.
Their oil based stain is pigment based. However, it is a micro-grind pigment, meaning that the pigment is ground much smaller than is typical. Thus it will go into smaller areas and more closely mimic what dyes do.
Nevertheless, it is 100% pigment based, an important distinction. Unlike dyes, which will fade in sunlight, pigment systems are light fast, and the Varathane stain can even be used outdoors under a suitable clear exterior finish.
Though it is unrelated, that Varathane stain uses soya oil instead of linseed oil as its base. Soya has a lower molecular weight, so it, too, will penetrate deeper into wood. Of course, this has virtually no bearing on the behavior of the pigment, but it is an interesting side note.
