OT Bathroom Tile Question
Ken Krawford
>I'm getting ready to put 12x12" ceramic tile in a bathroom. I know you are supposed to find the center line of the room a work outward from there but ....
Since this is a relatively small room, would it look ok to start along the long wall on the right side of the picture and only cut tiles on the left wall by the vanity and tub? Half of the cut tiles will be hidden under the toe kick of the vanity.
Re: OT Bathroom Tile Question
Ray, SW Ohio
>When I did my bathroom, I made it pleasing to the eye when sitting on the throne and upon entering the bathroom. I did not find the center, just laid it out and looked how it laid out. My 2�.
Agreed
Nat Robison
>I just did a 5'x8' bathroom in 4"x4" tiles and didn't worry about finding a center line. I knew the room was square since I built it. I started with full tiles in the most open spaces and put partial tiles along the wall where the toilet and pedestal sink are. It never visually occurs to me that there's any imbalance.
Just lay them out and put a chunk of plywood where the vanity and other fixtures will be. If you can live it, it will be fine.
>I think I would go for an even cut on both sides between the tub and the wall: 9-12-12-9, which would put 11" up to the vanity base.
Clint
Lee Schierer - McKean, PA
>I would draw the room accurately on CAD and put the tile in as a grid. You can move it around to see how it looks. I would probably use the bath tub side as a starting point and work toward the wall rather than have cut tiles all along the tub. I would also try to minimize the cutting that has to be done around the stub wall between the vanity and the tub.
Lee
Rod Peterson -- Ormond Beach
>I think most of the replies are taking you in the right direction. I'm no real mud man nor am I any sort of design geek, but in the tile/flooring layout I've done over the last few years in my and my daughter's remodel, I've used the most visible approach to layout—namely, what's the first thing you see?
Generally that's the threshold of the entry door to the room. That's a high priority (but not the highest) for a full tile. Then the wall/fixture in sight opposite the entry door (where your eye goes next). That's also a high priority, and higher than the entry. Third, a tub/shower curb is a high priority, and arguably the highest.
Do a practice layout starting with the center line you initially laid out, and see how the above priorities work out with it. If nothing else, you want to maneuver things so that you never have less than ½ a tile on any edge. Shifting center lines by that dimension will usually take care of that.
The rest is a balance—if you can have a full tile on the wall/fixture opposite the door and wind up with a 90% tile at the threshold, you'll have a very pleasing layout, and the eye will never pick up that the threshold tile isn't a full one. The opposite is also true, if you wind up needing to cut the opposite wall/fixture tile because of other considerations.
The ultimate goal, is not to have any chiclet tiles (very thin) in your layout. You may have to do some maneuvering and you may have to compromise on some of the rules, but you should be able to get a very nice result. And no one will ever notice…it'll just seem right, and they'll have no idea why. But you'll know.
Rod
RickS
>For your tileing needs go to http://johnbridge.com/vbulletin/index.php
You think the guys here at wood central are good? You should spend some time at this site. By far the best "I need help" web site out there.
All of the above, and....
Grant Smith
>Try to put the closet flange in the intersection of four tiles. This way you can make a 90 degree cut on each of 4 tiles and surround it. You really don't want to end up having to put a hole in the center of the tile for that closet flange. You have several inches of fudge factor to slide it left and right, up and down and still not have to cut a "U" shape. You will still be able to achieve the other ideals outlined here if you think it through well.
FWIW,
Grant in Iowa<---tiled 8 bathrooms in the past 3 years....
Hamish
>Thanks for the info, I will bare it mind, as I am about to tile my own bathroom.
Hamish
An side question...
Tony - Memphis
>Ok, this is actuallu ww related. I bought some real nice tile at Lowes on clearance to use for a tabletop. This tile is some sort of marble I think (stone maybe? dunno) that has depressions, holes, cracks, etc. In other words, it ain't glazed or smooth. My question is about grouting. How do you grout a material like that? And while I'm asking, what would be a good substrate for this tabletop that will live on a covered patio, but will see rain form time to time?
Thanks,
Tony
Re: An side question...
Nat Robison
>I did a bathroom floor in tumbled marble from Lowe's which sounds much like what you're describing.....holes, depressions, etc.
You basically just grout away......I can't envision a way to avoid filling all the "defects" along the way. I used a grout color that didn't contrast heavily so it doesn't draw attention to those areas.
Also, make sure you use a sealer before grouting, it makes it easier to remove the excess grout and haze.
Tony - Memphis
>Thanks. Yep, that sounds like exaclty what I have. These were accent strips that they marked down to $0.99 or something. Didn't know about the sealer. Thanks for that info.
Tony
Jim Dillon
>Tony,
For something as small as a tabletop, you shouldn't have to worry. My wife and I tiled a 400 sq ft floor (on the diagonal) last summer with tile that sounds a lot like what you have. Try to scrape as much of the excess grout off by holding the rubber grouter (I forget the real name for the tool) nearly 90 degrees to the surface of the tile (after you've packed the grout into the spaces by holding the grouter at 20 degrees or so) and go diagonally to the tile spaces to avoid pulling the wet grout out. Then, using a nice big sponge wrung nearly dry, go SLOWLY over the surface of the tile, again diagonally. Wring the sponge out, and do this a number of times until you see virtually no grout haze when the thin film of water drys. For something as small as a tabletop, you should be able to get all the grout haze off, but in case you don't, they make grout haze removers. Yes, grout will get into some of the depressions/cracks, but use your sponge to loosen the grout and lift it out. It is a pain on a large area, but on a small area it will be a piece of cake.
I have no experience with outdoor applications of tile but would guess that a well sealed surface/substrate would stand up to occasional rain; after all, folks mop tiled floor - generally on plywood substrates - all the time. But just in case, take a tip from the shower tilers, and consider using cement board as a substrate. If you do use plywood for a substrate, use a mastic that is indicated for use on plywood. Polymer fortified Laticrete, and Mapei are two well-known mastics that I've used and had luck with. Good luck.
Jim
Justin Szeliga
>You could just grout away w/a grout float & wie things down as the instructions say & then take a stiff plastic brush to the tile faces & clean out the pits in the tiles. Not practical for a floor or a shower wall. I know this for sure.
Peace
Justin
Justin Szeliga
>With 12"x12" I find center & lay the tiles out on the floor, first butting the line & then straddling it if that doesn't work out right, then shift things to avoid having less than 1/2 a tile but against anything, then & start making compromises to hide the smallest tiles.
Sometimes I use center, sometimes & have to shift off it.
Peace
Justin
Grant Smith
>Tony,
Sounds like you might have slate. Regardless, any porous tile that has an uneven surface should be installed, then sealed maybe twice and then grouted.
-You can buy grout sealer for stone at a homecenter, but it will be about $30 per quart for the better stuff. be prepared for the colors of the slate to COME ALIVE once you do this.
-If you are cheap, you can also seal the stone with something like mineral oil from a drug store.
-when applying grout once the tile is sealed, be extra careful in the cleaning phase. Use lots of clean sponges and take care to get the grout ot of the nooks and crannies.
-When the grout sets for a wekk or so, seal the whole thing again.
Good luck!
Grant in Iowa<--- just laid ~250 square feet of slate...
John E in SC
>I've made exactly what you're talking about - a tile table that sits outside. I've actually made it twice - first time with plywood as a substrate for the tile, and despite using latex-fortified thinset which was supposedly for plywood, it failed within a year. I think there was just too much movement in the plywood with the weather changes. I remade it by putting cement board on top of the plywood, with tile on top of that. It's now going on 6-7 years, and looks great. I used smooth tiles, so can't help much with the grouting, but would like to mention that you can get bags kind of like big cake frosting bags to squeeze grout out so you can apply it just to the gaps rather than flooding the whole surface. Might want to consider that to help minimize some of the cleanup getting the grout out of the depressions.
HTH,
John
Thanks all! Great info.
Tony - Memphis
