Tapered Cherry Dresser w/PIX *LINK*
HC Sakman
>Hello Everybody,
This is one of my recent work. A cherry dresser with tapered sides.
Tapered cherry dresser drawers angle
Drawer fronts are solid, the rest is some gorgeous 1/8"x 12" cherry veneer (from A&M) on Baltic birch ply.
Cherry dresser handle detail
Drawers feature hand cut dovetails on all corners. Handles are pau ferro. Drawer sides are European beech.
Tapered cherry dresser side
Finish id many coats of hand rubbed my mix of oil-varnish.
Overall dimensions: 60" wide, 24" deep and 45" high.
Drawers are almost 30" wide, 12" high and 22" deep, which are massive drawers!
Thanks,
Chico...
My Website
Re: Tapered Cherry Dresser w/PIX *LINK*
Nice work as usual, Chico
>That cherry veneer really has some shimmer! Nice pulls, too. Thanks for posting this.
Cheers,
questions
Bill Tindall, E.TN
>The depth of luster comes through even in a picture of the side. Rich!
What is the A&M source? When veneering the baltic birch (how thick) do you still veneer both sides?
Stuart Hough
>Beautiful work Chico! You are a master!
>Chico,
Nice job my friend. Question....did you use under-mount drawer slides? Just curious.
Great job on the pulls by the way.
Tom
Check Woodfinder *LINK*
>... and tell A&M that Woodfinder sent you. :-)
A & M's Woodfinder page
Good question
>I was going to ask but then for some reason I figured he used traditional runners. Now I wonder.
Answer
HC Sakman
>Hi Tommy, Ellis,
Yes, drawers are on Hettich V6 Quadro (Sounds like a car model!;-)soft self closing runners, which were requested by the clients. Whoever opens and closes a drawer mounted on this hardware, want the same in their furniture. All around tolerances are +/- 2mm, otherwise they don't work perfectly.
Thanks guys.
Chico...
Answer and a picture
HC Sakman
>Hi Bill,
Since the sides were built with 1/2" and 3/4" Baltic birch ply as a "torsion box", I left inside un-veneered. I also should mention that the venner's original size was 1/8" thick, 12-1/4" wide and 12' long. Veneer is wrapped around from side to top and other side continously. Thanks to the TV and other electronics on top, it's difficult to photograph.
By the way, solid drawer faces are not that bad either! ;-)
All have been sanded to 600 Grit and initial coats are rubbed on with 0000 steel wool and every coat was buffed.
Ellis had already answered your question re: A&M.
Thanks,
Chico...
Thomas S Stockton
>Very nice Chico, I really like the handles. When are you making them a cabinet to hide the Tv junk?
Tom
Rob Stokes in North Vancouver
>At the risk of having a dissenting opinion, Chico - I don't think that piece is up to your usual standards. You have a very good eye for curves and this piece, well, it doesn't have a lot of those. In fact it's blocky and a bit reminiscent of older Danish furniture.
Now - perhaps this piece was made with a lot of input from the person who commissioned it and perhaps it's exactly what they wanted, but if you hadn't said this was one of your pieces, I would have bet against it. Although the pulls have your name all over them.
Rob
Nick Tuzzolino
>Beautiful, Chico. I am finally learning to handcut dovetails. I've got a long way to go, but like you said before, PRACTICE, PRACTICE !! Yours are my inspiration.. Nick
HC Sakman
>Hi Tom,
Yes, handles turned out great. I designed them and friend of mine Harvey Brooks turned them for me. All the posts and stepped tenons and holes are done in a drill press with plug cutters and dril/forstner bits.
They actually ordered a highboy (32" wide, 18" deep 50" high) matching to this dresser as well as a credenza for their dining room.
Nothing for TV junk though.. Perhaps later. They already have 6 pieces of mine in their house.
Thanks,
Chico...
HC Sakman
>Hi Rob,
Yes, client had great amount of input in this piece. It meant to be a modernized Art-deco rather than "Danish".
When you say "your standards" I guess you meant "designwise", right? Well, this is like enjoying blues and when your favorite blues musician plays rock, you may be diappointed type of thing I guess. Nevertheless, I think design was on the money, because client's wife was almost crying from joy when she saw the dresser in her room.
This piece has been executed to the perfection with all the grain/color matching and flowing...narrow pin hand-cut dovetails, etc. The whole thing was truly painstaking to construct. Simpler designs with no frills are usually far more demanding to execute "perfectly". Not to mention approx. 5' width, 2' depth and 4' height to make matters little more challenging to keep me on my toes.
Thanks for the comments Rob. I'll be making more curvy stuff, don't worry. ;-)
Chico...
HC Sakman
>Thanks Nick! Will you guys come up here this summer?
Chico...
>LOL!! Glad you took my comments in the way they were meant - I'm always a bit nervous to speak out like that on most forums.
I had a hunch the design was heavily influenced by the person commissioning the piece because the piece is so different than what you usually make if left to your own devices. And I also have no doubt it's built to the highest standard, but it's the aesthetics of the piece that got notice.
Nice execution though, and glad it was well accepted.
Rob
I agree with Rob
Mark Valsi
>Chico,
I think you know I have a very high opinion of your work. I often go to your site, just to drool over the lovely piece of art you have created.
However, I don't care for this piece at all. I am glad to know that the design was not yours !!!!!!!! If I ever saw this in a store or gallery, I would never guess it was one of yours.
But on a positive note, I'm wildly impressed with the dovetails, as usual !
