Mostly OT - Learning small engine repair
Stephen Kirk in Quakertown, PA
>OK, I'm not really much of a mechanic, but as I become more of a woodworking and somewhat of a farmer, I find myself having more and more things with engines and moving parts and stuff that need constant maintenance and fixing. I keep an eye on my local community college and such, hoping for the courses on small engine repair, but I never see any. I think I may have to head to books to learn these things. I'd love some decent guides about how most small machines work (chainsaws, mowers, chippers, etc) and that may also talk about what kind of tools you'll need. I know I'm missing things like gear pullers, many sets of pliers, adjustable wrenches, etc.
I spent a while on Sunday attempting to get a chainsaw running again. I could get her to run, but attempting to throttle it up killed the engine. Cleaned air filter, replaced spark plug, cleaned spark arrestor, even turned up the throttle a bit. Got her to run at full throttle, but it's touchy. Luckily, all this was in the owners manual.
Thanks in advance!
Re: Mostly OT - Learning small engine repair
>Part of our Industrial Arts program in Junior High School was learning small engine repair. I quickly learned that I had an aptitude for woodworking. ;-)
Tom
Try cleaning the carburetor..
John E in SC
>If your saw runs but chokes w/ full throttle, you may well have some junk or varnish in the carburetor restricting gas flow. More often than not when dealing with small engines, I've found this to be the problem, particularly in chain saws, which often sit for prolonged times between uses. I've learned (the hard way) to never leave gas in a small engine unless I know for sure I'll be using it in the next month. With my chainsaw, I empty the tank and run it until it runs out of gas. Stabil may help, but I wouldn't depend on it. It's usually pretty easy to take the carburetor out and spray w/ carb cleaner, then blow out the ports w/ compressed air. Also check your fuel filter, if it has one.
As far as a good book, I really don't know any, but have seen manuals for Briggs and Stratton motors here and there. Might try auto parts or farm supply stores. Of course Amazon probably has some as well. Usually doesn't take a whole lot of tools unless you're completely rebuilding one. Most stuff can be done with just the basics and a willingness to try. Just be careful when you take stuff apart so you can remember how it goes back together. Label parts, draw pictures, etc.
HTH,
John
Curly Smith
>For web-based small engine help: http://www.jackssmallengines.com/do_it_home.html
Click the icon on the Right side for specific engine or general repair manuals. Your local library may carry some and might be a good place to determine which manual(s) are of most use to you.
Chainsaw specific: http://web.archive.org/web/20051018044450/www.madsens1.com/sub8.htm
Listen to the WAV files under "Saw Tuning" to make sure that your saw is adjusted properly. BTW - if the carb on your saw has plastic adjustment limiting caps then you might consider removing them. They frequently don't give sufficient range to properly tune older engines.
Re: Try cleaning the carburetor..
>>...you may well have some junk or varnish in the carburetor restricting gas flow.
That's the truth. What's worse, you can take the carburetor apart and look down the jet and not see any problem! That happened to a honda generator I have - it drove me crazy trying to get it to start and run cleanly until I happened to think of possible varnish buildup on the inside of the jet. A few seconds with a piece of wire fixed everything.
As for small engine repair, you'll find almost no help in owner's manuals. It is difficult to find detailed information about specific models. There are, however, some excellent general books available for learning the basics. I found one such book that was a big help to me with small engines, even after years of experience repairing and rebuilding motorcycle engines.
more sources
Tim Greif - West of Chicago
>http://nevadawalrus.com/index.html
http://www.perr.com/forum/viewforum.php?f=2&sid=1921f3e4c1b8873272a4739f010cf449
Larry Marker
>Check out the small engine shops where you live. The small one-man shops probably won't be much help, but if you have a big lawnmower dealer that carries several brands, they will probably also have a good stock of parts, tools, and repair manuals.
Small engines need three things to run -- fuel/air mixture, spark, and compression. Most engines that are hard to start and/or run poorly at all speeds and loads have plugged up carburators and/or gunked up fuel lines. If it won't start at all, it may have a busted spark plug or a dead magneto. If compression is bad, throw it away.
Many small engines of the weed eater and chain saw class have a diaphram in the carburator. These generally should NOT be drained and stored dry -- the diaphram will dry out and the carb may need to be rebuilt next season. My small engine instructor said to store such engines full of fresh fuel with Stabil added. Your mileage may vary.
Larry
