>I picked up a few logs of this wood along a road here in Central Florida. I have been tol it is Florida Rosewood. But also been told it is not. Best I remember it had a leaf that looked similar to a small maple leaf. It is a fairly hardwood and machines nicely.
Keith Newton, LR, Arkansas------WebKitFormBoundary
Guest
Re: Wood I.D. Help-Pic 3
>My first guess would be Redbud, although it would help to see a larger area of the bark. The thinness of the sapwood line, and carpenter ants in the pith area looks right also. It is medium soft density. Not likely to have had a long straight trunk.
I am pretty sure that mimosa has smoother bark than this.
You can get as many guesses as there are people who respond - wood is difficult to ID by looking at photos of log ends and boards since the natural variations are wide and many species appear similar at that distance.
If you section a small sample of end grain and look at it through a magnifying lens, you may be able to pin down the species. R. Bruce Hoadley describes how to do this in his book "Identifying Wood".
The thread in the link is another wood ID thread which might be interesting. I got a sample of the wood from Joanne and looked at it under the microscope.
>From the info given, its chinaberry - Melia azadirach. Everything in photos - color, thin layer of sapwood, rough bark - is consistent with this naturalized species.
>Thanks to all who responded even though I am still not sure of the species. I am leaning towards the mimosa because after Googleing it and seeing pictures of the leaves my memory was jogged and I am sure the couple of leaves still attached to the logs looked like mimosa and not as I described in my first post. Thanks again
I'd say not mimosa based on the color and the bark. All the mimosa we have around here has a greenish cast to the wood and a smooth bark. Is it a light-weight wood, compared to say citrus? Mimosa would be noticeably lighter in weight, even green. If it had a leaf similar to mimosa, then chinaberry is a probable.
>Jacaranda would be my guess based on the "Florida rosewood" comment. I believe mimosa, which was mentioned, is another name for this species. I have heard the wood described as "rosewood" and that it is not that nice brown figure when cut, but turns to that. I have had a friend who does tree cutting looking for some of it so I can see if it is as described.
