metal detectors
metal detectors
metal detectors
Mike Heili
>Can anyone recommend a metal detector to someone who plans on milling timber with a portable sawmill?
Re: metal detectors
Re: metal detectors
Robin Corell in Atascadero, CA
>I have been milling my own lumber since 1994 and I would recomend saving your money and time to pay for sharpenig and replacing the blades from hitting objects that are too deep to be detected or are not metalic. The most damage I have experianced was from a porcelin insulator, and Iv'e hit two.
If you are milling for yourself it is a cost of getting the wood. If you are planning on milling for others the risk of hitting objects is customarily passed on to the owner of the logs as a blade surcharge for each ruined blade.
Robin
Re: metal detectors
Re: metal detectors
>>...recommend a metal detector
Mike,
I bought a Lumber Wizard wand-type detector long before I got my woodmizer sawmill. I was a little disappointed in the sensitivity of the wand, perhaps because I was used to high-end metal detectors for items buried deep in the ground. The wand will pick up metal only a very few inches deep in wood so you would have to pass it over the cant every few boards or so. However, this is time-consuming and difficult due to all the steel in the mill itself such as the dogs holding the logs in place.
The most use I've found for it was isolating metal in some slabs. We knew the metal was there because of blue streaks in the wood. I do use it to check the lower 4-5' of trees on fence lines due to the high likelihood of embedded barbed wire. Most of this wire extends very near or through the surface but even then may be hard to see due to vines and such. It's easier to check before the tree is on the ground and especially before bucked into lengths for the sawmill.
I suppose I would try using it on the sawmill if I made a cut and saw blue streaks in the wood, or if I was down to my last blade and milling a tree from an unknown source. (Yard trees and fence line trees are the worst - trees from the woods rarely have embedded metal.)
It's interesting to see the things found in trees. People sometimes post pictures on the sawmill forums. I once found a file someone had evidently hammered into a tree a half century ago.
Re: metal detectors
Re: metal detectors *LINK*
Terry Quiram
>No first hand experience with this unit but I have been dealing with this company for many years and have never been disapointed. You can call them and they will answer your questions.
Metal Detetor
Re: metal detectors
Re: metal detectors
Mike Heili
>I was looking at the Lumber Wizard but for the exact same price I could get a Bounty Hunter and use it for treasure hunting when not milling lumber. I was wondering how the treasure models would perform in comparison to those designed for wood use. Judging from what I have read the results might be simmiliar. Dissapointing either way.
Re: metal detectors
Re: metal detectors
>>...wondering how the treasure models would perform
The treasure models I have (and have had) were much more sensitive than the Lumber Wizard. However, they still would not be very useful when the log is sitting on the sawmill due to all the steel in the mill.
Also, you would have to turn off any discrimination circuitry since the default on many models is to discriminate against ferrous materials in favor of copper/sliver/gold, etc. The model I use now (Minelab Explorer II) requires an effort if I want to pick up small wire and nails. Also, I think circuitry must be optimized for ground elimination, not wood elimination since it seems less sensitive in wood than dirt.
