OT Computer "User account" Questions.
>My Computer Goes to sleep and then logs on with a picture and the word Owner beside it. You click on that to "Enter" At the bottom of the screen, it says something like "once you log on you can go to Control Panel and then to User Accounts and change the settings". So, I went there with the intent of either Turning the whole thing off or resetting the timer so that the thing won't go to sleep quite so fast. I found a second Account that is labeled "ASP.NET Machine A..." and the text under it says its a limited account. Anyone know what that is and what it is for and any reason I should not omit it?
I owned this machine for years and the "Owner" Screen never appeared. Sure would like to skip that step.
Re: OT Computer "User account" Questions.
Thanks and a question about the answer?
>It says something about "If one works with ASP.Net Development projects" it is important to keep it, otherwise it won't work right. What is an ASP.net and how do I know if I use it.? Would I know, or is it something running in the background?
This sounds like a minor security problem to me, and I am tempted to remove it, but I cannot know if that would deny access to something that needs it or if it would help block out something that should not be getting in anyway.
Re: Thanks and a question about the answer?
Curly Smith
>.Net Framework allows you to run ASP.Net programs. The user account that .Net Framework created is only needed if you are an ASP.Net programmer. Since you're not an ASP.Net programmer, it's safe to delete the account.
