Re: Delta band saw
Lee Schierer - McKean, PA
>I had the same problem with mine. (It is a Chinese made saw that I purchased in Canada) When you tightened the screws properly the bearing would rub on the housing and not turn. I took mine apart, took the housing to work and clamped it up in a milling machine. I used a ball end mill and carefully milled away the aluminum until I had enough clearance for the bearing. It took less than 30 minutes to do with several trial and error assembly steps until I had enough clearance. Most any machinist with a Bridgeport could do the work for you in a jiffy.
I also added some .005" thick UHMW tape to the slide for the lower blade guide blocks to take out the free play.
Both fixes made teh saw work noticeably better.
Lee
