OT Ceramic Tile Question
Ken Krawford
>I'm tiling a bathroom today and the tile will meet carpet at the door. I had planned on using a marble transition at the junction. Is this correct or is there something better?
Thanks.
Re: OT Ceramic Tile Question
That depends on
Dustmaker Mike
>does it meet level or is the tile above or below the carpet. I like the look of wood thresholds. I use brass screws to hold it down in case I have to remove it. What ever you use make sure the bottom of the door will clear it. I guess it all depends on the look you want. Have fun I have two more floors to go before I am done with them, and start the next projects.
ken raddon
>Better is in the eye of the beholder. I own a carpet cleaning company and I have seen everything from marble to wood to nothing at all.
One thought about it is marble and ceramic/porcelin tile are two very different surfaces. For example marble will completely haze over (the shine will be gone) if you get the slightest bit of acid cleaner on it and man made tile wont. You didn't ask about that so I hope unsolicited advice doesn't offend.
Ken Raddon.
paul in AZ
>There is no "best" way.
In my current house I have bathroom tile butting directly onto bedroom carpet with no threshold and in the rest of the house I have 'thresholds' in doorways between LR/fam rm./kitchen.
These are contrasting, almost black granite about 6 inches wide. Decorative and perhaps a little more formal looking.
To my eye using wood presents too much of a mixture of materials.
As long as the thicknesses match and transitions are flush the only criterion seems to be if you like the look.
Depends on the transition
>I'm just completing the second bathroom of a remodel I'm doing. In the first I used a marble threshold to transition from parquet to white penny round tile. I did have to excavate the parquet to get it level with the tile. A wood threshold would have been the wrong design element. In the just completing bath, there's going to be carpet over the parquet up to brick colored marble tile, which stands about 3/4" higher than the parquet, so I'm going to interface the tile and carpet at the edge of the door with a narrow strip of cherry rather than just butting the carpet up to the tile.
Clint
Dan Donaldson
>I used a marble threshold that sits proud of the floor by about 1/4 inch. This is so that if "something" runs over for any reason, the water on the floor doesn't run into the carpet. (of course this NEVER happens with the newer low water flush units ;-))
George Koch
>Ken, raised marble sills are normally used at bath doorways to keep water spills confined to the tiled area as previous posted and also to get a tighter fit to the door bottom and still be able to clear a bath mat if used. George
Another option..
John E in SC
>You can also buy metal edging (silver or brass finish, probably others) designed just for what you describe. It probably on 1/2 - 3/4 inch wide, and part fits under the tile, and then it has a lip that fits over the carpet. I used it in a few places in my house. I think it looks pretty good, and is very simple to use. You can get it in the big box stores. Depending on your colors, I think it looks better than marble.
Jim Dillon
>Ken,
As others have said, use what looks good. We have the standard marble thresholds in our bathrooms (tile/carpet junction) and they work/look just fine. I have made a number of wooden thresholds from locust and QS fir where there is either a tile/carpet junction or a tile/wood junction and like them as well. In the case of the homemade wooden thresholds, I used a good quality construction adhesive to hold the threshold down on the tile side and that seems to work very well. If you use a TS to cut a bevel on each side of the threshold, watch your fingers as the bevel is very shallow and the threshold is relatively thin, say 3/4-7/8 depending if you have a door. I don't know what the tile guy used to hold the marble thresholds down, but I would bet construction adhesive (or double-sided tape??). Hope this helps.
