OT: Yard roots
OT: Yard roots
OT: Yard roots
John Weber
>We have many trees on our lot, large mature sycamores and maples, smaller pines, and ornamental cherry, maple, and others. Lots of trees. It seems in the last year or so I've got many roots coming to the surface. Most are small (under 1" diameter), but there are several older larger roots.
Can I just cut them out? That is cut each exposed ends and remove the section in the yard. Our home is over 100 year old so stuff had been growing here a long time. Overall everything seems healthy, but last summer was fairly dry.
Thanks - John
Re: OT: Yard roots
Re: OT: Yard roots-don 't cut them!
Tom Dunlap
>The very shortest answer is, don't cut them without expecting to see some consequence to the tree.
I'm an arborist and professional Tree Hugger :)
Alex Shigo, google him if you want to learn more about trees, has told us 'It's all about dosage' Cutting a small portion of a large root system may have little consequence. Alternatively, cutting some portion of a weak or unhealthy tree may have seriously bad consequences. The roots are responsible for nutrient uptake, water uptake, starch storage and anchoring/support.
Trees are VERY tolerant of human abuse. There is probably no other organism in the world that will function at such a high level even after suffering from our hurts.
If you're finding more surface roots there are likely some very basic changes in the area. Roots grow towards nutrients, oxygen and water. If one of those is lacking the roots die and others grow towards where they find the three needs. If the water table drops or raises the roots will adjust. If soil is washed away or overfilled the roots will attempt to grow into a place in the rhizosphere where they can survive.
The best way to deal with surface roots is to kill as much grass as possible, anything less than your whole yard isn't the best for the trees hahaha! and then spread coarse woodchips of the same species about 5-6" deep. Keep ALL mulch away from the trunks of trees. Think donuts not volcanoes like we see too often. Volcano mulching is BAD!
There have been times when I have had to cut roots. When that is needed make clean, straight cuts. A recip saw works well in this case and doesn't disturb the rest of the root like chopping can.
Re: OT: Yard roots
Question
Dustmaker Mike
>why wouldn't you just rebury them? I have a River Birch in the front yard and two of the small (1/2") roots are showing though the rasied bed I have it in. I was just going to bury them again. Is that a good idea? It is about 20 years old and I know it started to turn color last year in the summer because I was in the middle of moving and did't get a chance to water it. Whan I got it watered good enough it came right back.
TIA
Re: OT: Yard roots
Topdress roots
Tom Dunlap
>Topdressing with some good soil is also an option if mulching isn't desireable. Be sure to use soil that drains well. Keep the topdressing to only about three inches maximum or the other fine roots in the upper soil layers can be suffocated.
Tom
Re: OT: Yard roots
John Weber
>Tom,
Thanks, there are a few annoying smaller roots, so I may remove them, but I'll leave the rest alone. Soil level seems decent and the top soil is generally very good, I bet the dry summers the last few years may have had an effect. Water lever seems fairly constant with seasonally variation according to my sump pump.
I sent you an email on another subject.
Thanks - John
Re: OT: Yard roots
Suit and Tie it is
Dustmaker Mike
>Thanks I have some bulb flowers in the bed as well, that are doing great right now. I am going to wait to see what else pops up before I add soil and mulch.
Thanks Again
